| tbi injectors not spraying 1994 2wd 1500, 5.7 started this morning to warm up before i left, came back out truck had died. tried to start, turns over fine, no fuel out of injectors! checked fuel pump 12lbs pressure, all fuses fine am getting fuel to tb. jiggled wires behind dist. started and ran for about 30 sec.then started to flucuate and then died not able to restart |
| time to look for a dirty connection
| pull the air cleaner off, pull the connectors off of the TBI injectors, and check for Voltage there....... MY pickup had the problem, and it was a wire that had broke a little ways down from the wiring connectors |
| i know this is going to sound stupid but test for spark. i do have a reason for this. |
| replaced ignition control module.. runs great fixed problem |
| Thanks for the post back of the resolution. Just wondering did Brads suggestion point you to that conclusion?
| that was exactly what i was going to get to if he would have told me no. |
| glad it's fixed! ^^^^ and again thanks for postin back, it will help someone down the road
| Yep I knew that when you asked about spark.
| 96 5.7 vortec injectors | joe45 | Chevy Truck Forum | 16 | 08-24-2009 11:22 AM |
| 97, 98 v-10 injectors | dodgeram | Dodge Truck Forum | 0 | 05-28-2008 07:54 PM |
| 7.3 Injectors | mrjohnwayne | Ford Truck Forum | 6 | 03-02-2008 05:01 PM |
| Injectors | stryder | Dodge Truck Forum | 2 | 11-21-2007 08:35 PM |
