Old 10-20-2009, 11:35 PM   #1
fisherman49 is on a distinguished road
transmission problem
I own a 2001 GMC Sierra 2500HD. When I don't drive the truck for about a week, it sometimes does not engage into drive or reverse. I am told that this is caused by oil draining out of the torque converter. I am also told that I need a fluid pump modification to prevent this drain back. My first question is whether there is an easy fix for this (estimate is $1800) and the second is whether or not it is just easier to start my truck up every few days to prevent this drain back.
fisherman49 is offline   Reply With Quote
Old 10-21-2009, 12:17 AM   #2
Welcome to the forum and howdy from TEXAS. Sounds like the valve body to me try a can of Seafoam first just read directions and add to trans.
CORRECTION I meant Lucas the stuff is super. Thanks Leo just kidding thanks SHD.
Old 10-21-2009, 06:30 AM   #3
silverhairdeere's Avatar
even if this were true , when you start the truck , the converter would refill , how many miles on transmission , the smell and color of fluid , last fluid change ,if not lately try that and add lucas transmission additive , i and others on here swear by it
shd
Old 10-21-2009, 01:48 PM   #4
transmission
I have approx. 60,000 miles on the truck. It has an Allison transmission and when the mechanic looked at the oil, it was red but he noted a slightly "burnt" odor. What does the Lucas transmission treatment actually do to stop this backflow?
Old 10-21-2009, 03:42 PM   #5
changed the fluid and add the lucas , it helps with seals and cleans out the gunk , how do you know the converter is leaking back .
shd
Old 10-21-2009, 05:54 PM   #6
The problem with the torque converter was diagnosed by my local GMC dealer. They referenced Bulletin 030730011D.
Old 10-21-2009, 05:57 PM   #7
then there should be a service call back on them , which should be free to you .
shd
Old 10-21-2009, 07:51 PM   #8
How do you confirm that GMC needs to repair this problem? Is it suffice that a service bulletin has been issued?
Old 10-21-2009, 09:04 PM   #9
a TSB is not the same as a recall. dealership is not required to fix this on their dime and the truck out of warrenty makes it even harder to get them to pony up the cash.
i'd rather be hunting
transmission problem 01pewtergmc GMC Truck Forum 2 04-25-2008 07:59 PM
Transmission problem shorton5 Dodge Truck Forum 26 09-06-2007 01:27 AM
transmission problem 83 gmc joeydeherrera54 GMC Truck Forum 2 03-20-2007 09:27 PM
Transmission Problem z71chevy1996 Chevy Truck Forum 0 12-23-2006 04:05 PM
Clutch or Transmission problem?? nickelbn1 Ford Truck Forum 2 07-19-2006 04:14 PM
