| Instrment Cluster/CEL wire from pcm location ok guys got another one for ya with the 96. My CEL dose not light up even though i have a code in there (its the cat). I changed the bulb out the other day with a new one and i still don't work. a few months ago it came on for about a week or so then shut off again (still with codes in it). I did a little research and found out there is a wire that comes off the pcm and goes directly to that light but i can't find it in the diagrams that i have.
__________________ 96-GMC C1500 305ci 2WD K&N FIPK Cold Air Intake Rebuilt Motor (should have gone 350) and Trans 05 Nissan Xterra 4.0 V6 No mods so far Cost money to go fast...How fast do you wanna go? |
| common crab this ones for you lol
| Believe Brwn/Wht off pin #5 |
| well sry crab i found the problem. the new bulb i installed wasn't seated in the socket right. i had to take the factory bulb out of the plastic cam lock thing.
| Believe the bulb is located in the weak hand. |
| weak hand?
| | #7 | |
| 05 dash cluster | Farmall | Chevy Truck Forum | 6 | 06-11-2009 09:35 PM |
| ip cluster ? | mudseeker | Chevy Truck Forum | 0 | 05-31-2009 12:27 PM |
| Instrument Cluster ground Location?? | rdhack | Chevy Truck Forum | 4 | 04-13-2009 04:14 PM |
| Help Need a cluster! | Flopeyeman | Truck Classifieds | 0 | 04-12-2009 12:50 PM |
| Wire to Wire (Cycle News) | trucknews | Truck News (headlines) | 0 | 08-29-2005 01:30 PM |
