| Full Member Join Date: Jul 2008 Location: MI
| truck wont start only clicks Hello everyone I have a 1993 Gmc 1500 350.. the problem i have is it doesnt crank to start only clicks... i tested the starter its works fine.. battery is fully charged. battery connections are cleaned. cables to starter are cleaned also still no crank to start only clicks... thanks in advace Rick D |
| have you tried jumping it?
| Check your ground connection too.
| yup i tryed jump starting it same deal.. |
| If the battery test good and the starter test good, ohm your cables> Just because you have good connections doesn't mean the cables are good.
| well i have to check the ground... and test the cables Illl keep ya posted it it fixes it .. thanks |
| try to jump the starter solenoid and see if that works
| Might want to check if you get the same voltage from alt to block as across battery. |
| try putting the jumper cables from the battery to a clean ground. and to the starter selinoid......you may find the cable has broke down inside,
| I bet is the started selenoid that needs replacement, or your battery terminals. Try that. |
| truck wont start. bad cat? | lost in wyoming | GMC Truck Forum | 5 | 08-08-2008 10:26 AM |
| truck wont start | drewmowles | Chevy Truck Forum | 50 | 05-18-2007 02:32 PM |
| truck wont start when warm | redneck | Ford Truck Forum | 4 | 04-21-2007 06:16 AM |
| y wont my truck start right away? | eganracing | Chevy Truck Forum | 6 | 11-25-2006 05:57 PM |
| Please help... truck died now wont start | jarrod | Toyota Truck Forum | 8 | 01-31-2005 09:49 PM |
