Old 10-24-2009, 02:03 PM   #1
snider777 is on a distinguished road
help!
ok heres the deal i hope i can get it running today. 1989 gmc 5.7 litter fuel injected. was not getting gas. i replaced fuel pump and filter and thoses work properly.i tested it. the gas gets all the way to the carberator and gets stuck somewhere in there and dont allow it to start. i unpluged the lines going to the carb and gas came out of there. wha ti wanna know is what can i replace to get it starting. can there be a claug? can i test the 2 wires going into the carb to make the swing are go up and down? is there even a swing arm? please help. should i buy a carberatorr.... or should i test the wires going to there im confused help please?????
thanks!
snider777 is offline   Reply With Quote
Old 10-24-2009, 02:55 PM   #2
BernieB's Avatar
First off, if it's fuel injected then you don't have a carb. Most likely it's TBI, and there's a number of issues that could prevent the injectors from firing. I believe the most common of these would be a bad crank sensor.
Have you tried pulling codes yet?
Old 10-24-2009, 02:58 PM   #3
if i just buy a new one that would work?
and where is the crank sensor
pulling codes?
Old 10-24-2009, 03:09 PM   #4
BernieB's Avatar
Is your check engine light on?
Old 10-24-2009, 03:17 PM   #5
dump some gas down the throttle body and see if it spits
Old 10-24-2009, 03:17 PM   #6
no... gas gauge dont work as well.. hasnt since i bought it
i dumped gas down there and it wants to start... it starts for a sec then dies like it needs gas
i noticed another guy on here had same problem... and did ignition module and it worked?
Old 10-24-2009, 03:56 PM   #7
BernieB's Avatar
Check the bulb in the CEL, might be burned out, then try pulling codes once you get it working.
Old 10-24-2009, 03:58 PM   #8
sorry.... cel?? how do i pull c0des and will me buying a new tbi fix problem most likley
Old 10-24-2009, 03:59 PM   #9
o for the check engine light?
Old 10-24-2009, 04:21 PM   #10
Brad has a good chart on checking them look at some of his post somebody just put it on a post the other day.
