| | #11 |
| Well then, have at it. At least now you know what to expect when you start taking it apart, instead of having springs and stuff flying every which way all over the shop.
| | #12 |
| well i think ima wait until next week to do it so i will have the money to take it to the dealer and have it bled once the leak is fixed. bleeding the echu requires either patients or a tech 2 niether of which i have.
__________________ 96-GMC C1500 305ci 2WD K&N FIPK Cold Air Intake Rebuilt Motor (should have gone 350) and Trans 05 Nissan Xterra 4.0 V6 No mods so far Cost money to go fast...How fast do you wanna go? |
| | #13 |
| just took off the module, its not leaking. seal is good
| | #14 |
| Why is it wet then? Just really happy to see you?
| | #15 |
| i don't know maybe just had oil spilled on it so many times or just got hot. just called dealer to see how much they want to bleed the ecbm and its $89.
| | #16 |
| If I were in your position, and already had it apart, I think I'd change that gasket anyway, just because...
| | #17 |
| all that holds it on there id four T25 torx screws no fluid was present behind gasket.
| | #18 |
| i found this pdf about abs systems. Its a pretty good read, lots of information. id put it on here but its to big to be uploaded
| 4.6 oil leak?? | Robert78.5 | Ford Truck Forum | 3 | 12-11-2008 05:57 PM |
| radiator leak | stelmadl | Chevy Truck Forum | 25 | 08-31-2008 11:39 AM |
| Oil Leak.... | nnunez | Chevy Truck Forum | 3 | 01-17-2008 07:07 PM |
| oil leak | scottie | Chevy Truck Forum | 10 | 01-22-2006 07:00 AM |
| Just a little leak | 4x4 | Ford Truck Forum | 8 | 11-07-2005 01:55 PM |
