Old 10-28-2009, 04:07 PM   #1
Wyley87's Avatar
Wyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to behold
ABS Leak fixable?
ok guys got some new info about my brake issue that ive been having. I was just out looking at my truck checking my fluids and noticed a leak on the abs module. I know that these units are suppost to be non-service able but all this is a gasket. It appears to come off via 4 torx screws.
question is can i take the ebcm off the top and use some black rtv as a gasket? here are some pics.
abs-leak-fixable-100_2259.jpg  abs-leak-fixable-100_2260.jpg  abs-leak-fixable-100_2261.jpg
96-GMC C1500 305ci 2WD
K&N FIPK Cold Air Intake
Rebuilt Motor (should have gone 350) and Trans
05 Nissan Xterra 4.0 V6
No mods so far
Cost money to go fast...How fast do you wanna go?
Wyley87 is offline   Reply With Quote
Old 10-28-2009, 08:36 PM   #2
Wyley87's Avatar
come on boys been soakin for about 4 hrs now any body got an opinion?
No mods so far
Old 10-28-2009, 08:43 PM   #3
BernieB's Avatar
Yup... Replace the unit. Seriously, I know it doesn't look like a difficult fix, and probably isn't, if you have the right parts and know how it comes apart and goes back together, but I'm not sure I'd want to start tearing something apart that I didn't even have a parts diagram for, let alone the proper gasket to put in it when I got it apart.
Old 10-28-2009, 08:50 PM   #4
Wyley87's Avatar
well the only thing is i dont have the money for the $500 price tag for a new one. my plan was to replace the gasket and then bleed as much air as i could out and then take it to the dealer the next day. to have it bled the rest of the way
No mods so far
Old 10-28-2009, 08:57 PM   #5
BernieB's Avatar
What about a used one from the junkyard? Heck, even if the one from the junkyard is no good, chances are the gasket will be. At the very least a junkyard unit will give you one to tear apart and play with before you go tearing into the one on your truck.
Right now you have a minor leak, and you can just keep adding fluid but still drive the truck. But if you tear it apart and can't get it back together, then what? Then you have no truck, and probably not even a core to turn in when you scrape up the money for a rebuild. I'm all for saving a buck here and there, and I know about not having the money you need right when you need it, but the last thing you need is a worse problem, right?
Old 10-28-2009, 09:01 PM   #6
Wyley87's Avatar
yea i know bernie, its just that i thought for a long time it was something i was doing wrong when bleeding them out only to find out it wasn't me but a $500 part. It just seems like a have to constantly bleed my brakes like once a week to keep the air out, kinda driving me nuts. but maybe i'll my a few phone calls tomar and see what i can find
No mods so far
Old 10-28-2009, 09:08 PM   #7
BernieB's Avatar
Hey, you can always try a little dab of silicone sealer, or a spot of epoxy, just to plug the leak. Might be enough to fix the problem until you have the money to replace it.
Old 10-28-2009, 09:25 PM   #8
i don't see a leak, just dirt and debris.
clean it and see if it gets wet again.
i'd rather be hunting
Old 10-28-2009, 10:10 PM   #9
Wyley87's Avatar
i cleaned it two or three times. dried it off and let it sit over night seal is still wet.....
No mods so far
Old 10-29-2009, 10:01 PM   #10
Wyley87's Avatar
hey look what i just found in my chilton book
No mods so far
4.6 oil leak?? Robert78.5 Ford Truck Forum 3 12-11-2008 05:57 PM
radiator leak stelmadl Chevy Truck Forum 25 08-31-2008 11:39 AM
Oil Leak.... nnunez Chevy Truck Forum 3 01-17-2008 07:07 PM
oil leak scottie Chevy Truck Forum 10 01-22-2006 07:00 AM
Just a little leak 4x4 Ford Truck Forum 8 11-07-2005 01:55 PM
