Old 11-02-2009, 09:16 AM   #1
cyberma007 is on a distinguished road
Question Heater Problem Please Help!
Hi Guys, I am having problem with my Heater on a Yukon 2000 SUV, I have replaced the thermostat and flashed the Core, The core was clean and nothing in there.
there is enough coolant in the cooling system, What else can it be?
All this happened after i replaced the fuel pump, to replace the fuel pump i had to disconnect the battery, and i think it has something to do with that, but not sure what.
I check all fuses and they all look ok as well
Any help would be appreciated.
Thanks
cyberma007 is offline   Reply With Quote
Old 11-02-2009, 10:27 AM   #2
Crmzendrgone's Avatar
So you do not feel any heat coming out of the vents?
Old 11-02-2009, 10:39 AM   #3
No Zero, No heat from heater.
Old 11-02-2009, 11:28 AM   #4
but it still blows air?? look inside the engine bay and grab the heater hoses entering the firewall on the passenger side after the engine is up to operating temps. are both lines hot?? if yes, than your blend control accuator is not diverting the air through the heater core from the evaporator core. this could be a switch problem or a actuator problem and likely the problem being the latter of the two.
Old 11-02-2009, 01:02 PM   #5
You beat me to it Brad. That is what I was going to suggest seeing as how you said it started after you disconnected the battery I thought it might be an electrical issue, that being only if you feel heat on both heater hoses.
Old 11-02-2009, 01:07 PM   #6
Yes They are both hot, Someone told me one a different forum to remove the HVAC fuses and start the car and let it recalibrate Actuaters for about 2 minutes without touching the controls and turn off the car and remove the key and put in the fuses again and try to see if it works.
I am going to give it a try this afternoone and see how it goes, I hope that is the problem, sounds simple, I hate when stuff does not make sense.
Thanks
Last edited by bradrhale; 11-02-2009 at 02:37 PM. Reason: no related links to other forums
Old 11-02-2009, 02:38 PM   #7
i dont know about all that. seems to me that if a fuse was pulled, it can recalibrate anything because there is no power going to the unit. so with this in mind, how can it relearn with nothing there to relearn??
Old 11-11-2009, 01:37 PM   #8
Faxcion's Avatar
Faxcion is on a distinguished road
Isnt there a door that diverges the engine heat into the cab between the cab and those hoses?
ИO COP ИO SŦOP!
Faxcion is offline   Reply With Quote
heater switch problem lemoncoke GMC Truck Forum 12 02-23-2008 02:47 PM
Engine Block Heater problem 95 6.5 GMC Smiley GMC Truck Forum 0 02-18-2007 05:03 PM
Engine Block Heater Problem GMC Smiley Chevy Truck Forum 0 02-18-2007 04:57 PM
AC/Heater Problem 3500hauler Chevy Truck Forum 0 11-20-2006 08:44 PM
Heater Problem bubba8167 Chevy Truck Forum 5 05-28-2006 12:09 AM
