| Full Member Join Date: Oct 2009 Location: St Pete, Fla
| 1996 5.7 vortec/auto transmission jerky shift ok...onto my next item on this newly adquired truck. i have noticed when i drivethe shifting is abit of a jerk....doesnt feel grindin and i dont hear anything. so...im thinkin of takin it to a tranmission place..and have it checked out anythoughts? |
| anyone? i plan to check the fluid tonight when i get home. was reading some info on this and read that if the fluid is red/brown and somewhat runny and clear that the fluid is good and its not grinding, oh..and if theres no burn smell... anyone? the kid that i got this truck form said "supposely" the tranmission was rebuild bout 15000 miles ago |
| What gears do you feel the jerk in?
| all of of them lol |
| is it a late shift?? shift great except gives you whiplash when goes into the next gear?? shifts at high RPM?? idle a little high?? if yes to all of these, characteristic of a malfunctioning TPS. |
| what is TPS? yes to all....not a ruff whiplash...but noticible and it does feel like its abit late. the idle seems fine but when li let off the brake...at times the idle drops way low like it bout to cut off...i have to press down on the gas to get goin....squealed my wheels last nite lol |
| throttle positioning sensor. you really have to give it more gas when moving from gear to gear in an auto otherwise, it seems like it doesnt want to shift. because of this, it shifts in a high RPM creating an extremely hard shift. this however will not cause poor idle. it might if the IAC was south, though. |
| anyone have a pics refer of these items on this engine |
| Here you go. This should be what your Throttle Body looks like when you have remove the coverings and the duct work. Found this 411. Throttle Position (TP) sensor Like the older engines, the TP (or TPS) is mounted on the throttle body throttle shaft. The sensor is a potentiometer that varies the voltage output based on position (in this case, the angle of the throttle blade). At idle, the output voltage is around 0.6V, and at WOT this voltage is around 4.0V. The pcm sees the signal, along with the CMP, CKP, MAP and MAF to determine if the engine is accelerating or not. This affects many systems, including emission system and fuel calibration control. An erratic or faulty TP sensor will cause erratic engine performance. A DTC will be set depending on the type of fault condition the pcm sees.
| assume this is on top right where the air hose connects...are there gaskets or seals i should get if i remove this to clean? |
| 1996 vortec 305 missfire | Buroaktree | GMC Truck Forum | 11 | 06-02-2009 01:52 PM |
| 1996 vortec 305 to a 350 | jessie_london | Chevy Truck Forum | 6 | 02-03-2009 08:57 PM |
| 1996 5.0 vortec 300 misfire code | dwill80 | Chevy Truck Forum | 1 | 04-28-2008 05:03 PM |
| auto transmission won't shift and rpm& speed guages don't work | gmcer | GMC Truck Forum | 13 | 05-04-2006 08:27 AM |
| 1996 Auto transmission question | Blueoval | Ford Truck Forum | 0 | 09-18-2004 01:24 PM |
