Old 11-03-2009, 07:57 PM   #1
red tractor is on a distinguished road
91 K1500 5.7l studder problem!
When I first put the ethanol gas in my truck it started to studder in the bottom end on initial take off. I was wondering if anybody has had this problem?
red tractor is offline   Reply With Quote
Old 11-03-2009, 09:57 PM   #2
BernieB's Avatar
You mean E85? Your truck isn't setup to run on that.
Old 11-03-2009, 10:19 PM   #3
no, in oregon they added ethonal to our gas.
Old 11-03-2009, 10:47 PM   #4
BernieB's Avatar
Ethanol has less energy, per weight, than gasoline, but the concentration used (typically 5-10%) isn't high enough to really cause any noticeable effect with most properly tuned engines.
On the other hand, ethanol is hygroscopic, meaning it attracts and bonds with water. This is the whole principle behind "dry gas" (which is 90% alcohol). It bonds with any water that might be in the fuel system and lets it "burn" (the alcohol burns but the water flashes to steam and goes out the exhaust). If this is the first time you've used fuel containing ethanol it's entirely possible you had a little water in your tank that the ethanol bonded to and which is now being burned off. Also, if ethanol being added to gas is new in Oregon then it's also possible that the tanks at the station may have had some water in them, with a similar result.
Water in underground tanks is fairly common, the result of condensation forming on the tanks walls when moisture laden air is drawn into the tank as fuel is pumped out. Because the tank is underground it's cooler, and the excess moisture condensates out. Most stations have alarms on their systems to show when there's any appreciable amount of water in the tanks (the gas floats on top, being lighter) and anything more than a couple of inches has to be pumped out. (That was something we did weekly at the station I managed, using a hand operated pump that drew from the very bottom of the tank)
In any case, assuming this is something new in Oregon, then it might take a couple of tankfuls before all the water is completely out of the system.
Old 11-03-2009, 10:53 PM   #5
BernieB's Avatar
Oh, and I always used to laugh when people would accuse us, or other stations, of "watering down the gas". Since gas and water don't mix adding water to a tank full of gas serves no purpose. The pumps are going to draw from the top down, and until the gas runs out and the pumps reach the water level you'll get 100% gas, no water. Once the gas runs out though you have the opposite, 100% water and no gas, and the customer is stranded right there at the pump. Which would be a pretty stupid thing for any station owner or manager to want happen.
Old 11-04-2009, 08:18 AM   #6
My truck does the studdering all the time, not just sometimes. Maybe a fuel pump?
Old 11-04-2009, 05:50 PM   #7
I am required to run E10 by Oregon law. They don't allow the sale of pure gasoline for on road use.
Old 11-04-2009, 07:13 PM   #8
Drop in a bottle of Isopropyl alcohol. that will break down the water and burn it. You usually find it in a red bottle rather than a blue bottle.
Once you do that you will know if it is water related.
I have never had a vehicle that ran really well on E10.
Also you might want to run a bottle of dedergent based injector cleaner.
One other thing.. disconnect the ECM or just the battery for awhile to reset the ECM it may need to relearn for the E10. I have an 06 Grand Prix that came out of California. Couldn't get very good mileage. Finally had to unhook the battery for some other reason. Mileage increased from low 25 to upper 27 mpg range.
Scav.
Old 11-04-2009, 08:02 PM   #9
BernieB's Avatar
Considering the amount of alcohol already in the E10, adding more alcohol probably isn't a great idea. Especially on an older vehicle where hoses and fittings might not be compatible with that much alcohol.
Old 11-04-2009, 08:54 PM   #10
The only way to get rid of the water.
Ethonel just puddles the water. Then you get slugs. Isopropyl
actually breaks down the water so it mixes with the gas.
The older vehicles aren't compatible with any alcohol.
Scav.
88 k1500 Overheat problem repalced evryhting! still not fixed! HELP!!!! .ben Chevy Truck Forum 18 11-12-2009 05:31 AM
AC & Heater Control Problem 91 K1500 Silver jbbarry Chevy Truck Forum 14 10-22-2009 08:12 PM
98 K1500 4x4 Problem mikemitchell_20 Chevy Truck Forum 24 12-28-2008 03:03 PM
92 k1500 A/C problem sport Chevy Truck Forum 1 06-28-2007 07:53 AM
90 k1500 tranny problem solved smokensteve Chevy Truck Forum 3 02-19-2007 06:14 PM
