| | #21 |
| Found 'em... Looks like either they changed their specs or my memory was wrong, as the highest rating I see now is 875cca, which is still pretty good, and would be more than enough on my truck. I'll have to see in anyplace local carries them and find out a price.
| | #22 |
| Well, as if having weak batteries isn't enough, now the truck is requiring extended cranking to get started. Used to be it would start with just 1-2 seconds of cranking, but tonight it took a full 15 seconds to start. Glow plugs are good, so is the glow controller. No problems at all after it starts, so I'm thinking the filter's good (gonna change it next oil change anyway) and the pumps should be okay. Could just be that it's cranking too slow...?
| | #23 | |
Scav. | |
| | #24 |
| Yeah, that and the fact that it runs fine after getting started makes me think it's all due to the marginal batteries. Glow plugs aren't getting hot enough, starter isn't turning fast enough, and therein lies the cause and effect. I'll probably be changing the batteries tomorrow. Had to wait for a check to clear the bank, and that should happen tonight.
| | #25 |
| Hmmm... I may have to rethink this. I just found out how to read the date codes on the batteries in the truck and found one was made in May of '07 and the other in August of '07, and both are 6 year warranty. I still think they're undersized though, with 675cca ratings. I'd prefer 800 or better. Supposed to rain here the next couple of days, so maybe I'll wait for the weekend when it's clear and in the 70's, then pull both batteries, clean terminals, check grounds, etc, and have 'em both load tested. That'll tell me, one way or another. If they're bad though it'd be nice to get 'em replaced under warranty, but they were in the truck when I bought it, and the warranty is to "original purchaser" only... Darn. Oh well, they're Delco's, and there's no Delco dealer nearby anyway.
| | #26 |
| I think I'm going to replace all 8 glow plugs, just to be sure. I'll probably go for a set of quick start plugs. Anyone have any experience with those? Pros/cons?
| | #27 |
| what is that saying bad things happen in 3 or your case 3 or 4. I do know the feeling though.
| | #28 | |
__________________ Winners NEVER Quit , Quitters NEVER Win !!! | |
| | #29 |
| No, what I really need to do is load test them properly, then replace them if that shows any problems. Since both batteries are only around two years old if there's anything wrong with them I'll be surprised. I went over the electrical system again today, even so far as to take some resistance readings on the cables and grounds. All came back normal, so I know it's not that. I also went and checked the glow plugs again. The right bank is a PITA to get to, and there's a couple I simply can't reach without pulling the wheel, so I've decided I'll just buy a set and let the local shop I deal with change them for me. That should help with the starting issues. Then, the next step will probably be a better alternator, as that 100a stock unit simply isn't big enough.
| | #30 | |
Have you thought to possibly check the battery isolator to see if its functioning properly so that both batteries are getting charged? That is a fairly important part in a dual battery system and it can certainly cause problems if the isolater is not working properly.
| my dang truck won't start..1997 Gas Dodge Ram 2500 4x4 | jjg84 | Dodge Truck Forum | 6 | 02-29-2008 04:42 AM |
| dang! | peterbilt | Off-Topic | 34 | 08-21-2007 03:41 PM |
| Dang moderators | chevyguy | Off-Topic | 8 | 10-10-2006 08:41 PM |
