| | #31 |
| Banned (temp) Join Date: Jul 2008 Location: OKC, OK
| I am not so sure I call 100,000, a high mileage engine in todays engines. I would probably still run the manufactures reccomended 5w-30. And to be on the safe side and not get to heavy if felt the need to change, maybe a 10w-30, but that would be the max I'd go. JMO |
| | #32 |
| If yall want some info on filters check this out. Its anouther part of the reasons i switched from fram to mobil 1. Oil Filters Revealed - MiniMopar Resources (If yall are getting tired of hearing about me switching just say the word and i will be quiet)
__________________ 96 GMC C1500 305 2WD K&N FIPK C.A.I. Rebuilt Motor and Trans Mobil 1 15w50/Mobil 1 Filter 05 Nissan Xterra 4.0 V6 Royal Purple 5w30/Mobil 1 Filter Cost money to go fast...How fast do you wanna go? |
| | #33 |
| I use high mileage Castrol in my truck I have always used Castol but now that it has 169,000 plus miles on it I use high mileage. Now on our older MPV it's the only oil that will keep the HLA's from making noise. |
| | #34 | |
Also on an older engine there may be grime around seals and gaskets that the better oil will clean away. Often this is what has kept poor gaskets and seals from leaking. Scav. | |
| | #35 | |
__________________ | |
| | #36 |
| i are having brain problem ... pleez xplane weights. haha i completely forget what the numbers mean
__________________ Lukas "don your headdress" McDukas 97 Nissan D21 Hardbody SE Kingcab (77,500k) 86 Yamaha Maxim X 750 4 cyl, 4 stroke (48k) |
| | #37 | |
its really simple, for example 10w30 10 is the wt of the oil in cold weather 30 is the wt of the oil in hot weather
__________________ 96 GMC C1500 305 2WD K&N FIPK C.A.I. Rebuilt Motor and Trans Mobil 1 15w50/Mobil 1 Filter 05 Nissan Xterra 4.0 V6 Royal Purple 5w30/Mobil 1 Filter Cost money to go fast...How fast do you wanna go? | |
| | #38 | |
Only partly true....... A 10w is the temperature at which the oil will flow at, and the 30 is the actual weight of the oil........ I can get into how they get a 30 weight oil to flow at a colder temperature, if there is enough call for it, but I dont feel like typing that much tonight, and/or boring all of you..... If you want some info, go to Noria's website...... As for what I would run in your truck if it were me, I would go with a good conventional oil..... as some have said, The synthic oil is a natural cleaner..... It will clean the seals up, and sometimes remove the buildup keeping it from leaking........ I have a 1995 with 160,000 on it, and I switched to synthetic, and I developed a rear main seal leak..... At the high mileage, It can be rough on motors to change over.... Im not saying impossible, or that some havent had great success, and no problems, but, if it were me, I would only switch from one, and go to the other if the truck is over about 80,000 miles or so....... | |
| | #39 |
| Ok so I did my oil change and cut open my fram filter and it looks nothing like the one that Wyley87 has posted. I was not able to get a mobil 1 filter I got a ACDelco and will see how that one fairs. This filter was on the truck for 3500 miles with Castrol GTX 10w30 no additives.
| | #40 | |
| 100,000 mile tune up | Joe | Chevy Truck Forum | 13 | 06-21-2008 05:43 PM |
| 10K mile oil changes | 75K30 | General Truck Forum | 15 | 04-06-2008 06:33 AM |
| 1/4 Mile Estimate | 85s10383 | Chevy Truck Forum | 0 | 07-31-2005 10:18 PM |
| Going the Xterra mile (Toronto Star) | trucknews | Truck News (headlines) | 0 | 01-01-2005 03:30 AM |
