| Full Member Join Date: Nov 2009
| 99 gmc c6500 misfire I am working on a 99 GMC C6500 with 7.4L engine. Cylinders 5 and 7 are misfiring. I have replaced plugs, wires and those 2 coils. I have spark at the plugs. What else can cause a miss in those 2 cylinders? Compression is 140 psi. |
| clogged injectors?
| check the injector circuit in the fuse box and make sure there is a fuse and not a circuit breaker in it's slot
| Just to be clear, only 2 cylinders are missing--#5 & #7, they are next to each other. Where are the injectors? |
| run a comression check, you could have a blown head gasket
__________________ None of the secrets of success will work unless you do. |
| under the fuel line pushed into the intake
| He did, 140psi. (see the first post) Blown gasket was my immediate thought too, but not with compression like that.
| The reason I asked where the injectors are is because I don't see a fuel line along the intake manifold with injectors pushed into the manifold. Does this year and model have a fuel manifold at the rear of the engine? If so, how does that work? Could the manifold have 2 lines plugged? I heard that back in the mid-90's GM used such a thing on the Astro van, and that they had problems; did they use it in other applications as well? |
| wait a minuter, 99 wasn't that throttle body injection?
| 1998 Chevrolet C6500 (topkick) | batty1214 | Chevy Truck Forum | 5 | 11-08-2009 04:28 AM |
| Expidition misfire | Majesticfs | Ford Truck Forum | 5 | 12-10-2008 09:01 AM |
| 96 Z71 misfire problems. | bobkix | Chevy Truck Forum | 6 | 10-14-2008 04:41 AM |
| DumpTruck C70 or C6500? | amo43876221 | Chevy Truck Forum | 1 | 07-02-2008 05:43 AM |
| MisFire!!! Ive tried everything, help. | jaime7818 | Toyota Truck Forum | 4 | 08-09-2007 07:11 PM |
