| Junior Member Join Date: Nov 2009
| Hi. New to the forum, but have a repair question. Hello, I have a 98 GMC 1500 5.0 liter. Automatic. I've been having an issue with cranking. Sometimes it would sometimes it wouldn't. Once, it wouldn't crank on a Friday and I tried several times throughout and a couple times on the weekend. It woudl just turn over and over but never fire. Well, I was going to trying to gtdet it hauled someplace on the following Monday. I went out, and it cranked right up and ran perfect. It's been acting like that for a few weeks now. Well, I check the fuel pump pressure and it's right at 60. I even poured some gas into directly and nothing. It will turn over but no fire. So, I checked for fire at gthe spark plug. It was firing but it looked a little red and not blue. I put a new coil on it. Nothing. So, I put a new crank case sensor on it. Nothing. I changed the plugs, wires, and cap and rotor all about a year ago and I figured that if any one of them were bad now that it would at least fire but run bad. I don't know what to do, but I just can't keep changing parts out and I really don't have enough dough to come up with at once to take it someplace. Please help if you can. Thanks By the way, I unplugged the negative on the battery so that the computer could reset it's too. I let it sit for 30 minutes. Nothing. |
| Senior Member Join Date: Oct 2009 Location: St Pete, Fla
| if its turning and turning...but never fires, sounds like ignition to me have you checked plugs recently? the intermittant thing is strange though |
| yeah, I've check that and I've checked all the fuses. |
| Senior Member Join Date: Sep 2009 Location: MIchigan
| Kinda sounds to me like the coil is bad i've had similar problems with mine(96) is it the original coil still? if it is it will be riveted in if not i would one of the days it's not firing pull a plug and check for spark should be a real nice bright blue if its not i'd say replace the coil. Also it wouldn't hurt to pull the cap and check the cap and rotor for corrosion as that could also be part of the problem.
__________________ THEY DON'T BUILD THEM TO BE EASY TO WORK ON THEY BUILD THEM TO WORK "The Kamikaze" |
| Senior Member Join Date: Jun 2009 Location: Calico Rock Ar.
| Do you have a bunch of stuff on a single keychain thats heavy? Beleave it or not the weight of my keys fouled up my ignition one time and it did exactly that.
__________________ тнuмрıиg мч sкoаl cаи |
| | #6 | |
| Could be your ICM ignition control module is going bad. I am curious if you follow these steps when you did your cap and rotor a year ago? Quote:
__________________ | |
| all lights on guage cluster come on? if not could be ignition switch
__________________ 96 GMC C1500 305 2WD K&N FIPK C.A.I. Rebuilt Motor and Trans Mobil 1 15w50/Mobil 1 Filter 05 Nissan Xterra 4.0 V6 Royal Purple 5w30/Mobil 1 Filter Cost money to go fast...How fast do you wanna go? |
| Have you checked to see if theirs any codes are in the computer? Also where are you from what state? Good luck! GMC |
| Banned (temp) Join Date: Jul 2008 Location: OKC, OK
| My guesses would be Ignition Module first, then Coil. |
| ford repair kit | animalsrule | Off-Topic | 6 | 12-30-2008 06:46 AM |
| new to forum with clunking noise question | countryboy2373 | Chevy Truck Forum | 10 | 10-04-2008 06:08 AM |
| New to the Forum/ and have a truck question | southernracer | Chevy Truck Forum | 19 | 01-18-2008 10:44 PM |
