Old 11-12-2009, 04:08 PM   #1
RyanDL's Avatar
RyanDL is on a distinguished road
trouble with hot starts
I have a 2000 sierra and it will stard fine in the morning but after it warms up it has a terrible time starting but not if i start it up right after i turned it off, only if it sits for at least 5 minutes after being warmed up. It will start fine again after it cools compleetly down.
please help
RyanDL is offline   Reply With Quote
Old 11-12-2009, 05:25 PM   #2
1500cheyenne96's Avatar
1500cheyenne96 is a splendid one to behold1500cheyenne96 is a splendid one to behold1500cheyenne96 is a splendid one to behold1500cheyenne96 is a splendid one to behold1500cheyenne96 is a splendid one to behold1500cheyenne96 is a splendid one to behold1500cheyenne96 is a splendid one to behold
HMMMMM kinda sounds like the starter solenoid is getting ready to **** out but thats weird that it will start right up after you shut it down usually it will start hard all the time when its hot but thats where id start could pull the starter off and have the solenoid tested at the local parts store
THEY DON'T BUILD THEM TO BE EASY TO WORK ON THEY BUILD THEM TO WORK
"The Kamikaze"
1500cheyenne96 is offline   Reply With Quote
Old 11-12-2009, 05:28 PM   #3
Faxcion's Avatar
Faxcion will become famous soon enoughFaxcion will become famous soon enough
Is it trying to over heat?
тнuмрıиg мч sкoаl cаи
Faxcion is offline   Reply With Quote
Old 11-12-2009, 05:49 PM   #4
RyanDL's Avatar
nope no overheating or check engine lights
Old 11-12-2009, 05:51 PM   #5
RyanDL's Avatar
i had the alternater checked at advanced but they found no probs
thanks for the reply
Old 11-12-2009, 07:03 PM   #6
my65coupe is on a distinguished road
hot starts
sounds like th fuel press. reg is bad.
had same problem would start fine when cold but had to crank to get started when warmed up.
part was pretty cheap at auto parts store.
my65coupe is offline   Reply With Quote
Old 11-12-2009, 10:30 PM   #7
hotrodpc's Avatar
I would be leaning toward fuel presure regulator or fuel pump getting weak. Sounds like a vapor lock kind of situation. So you shut it off hot, then it will start right up, why?, because the fuel has not had time to vaporize just yet. Wait a few minutes, fuel has vaporized. Wait til cool, fuel vapor disappears. But, can't really call it a vapor lock problem because its a computer controlled, injected engine. So where is the fuel vaporizing at? Maybe in the fuel rail, and the regulator or pump is not pushing enough pressure to get through and push fuel to the injectors. I would do a fuel pressure test. Just my thinking out loud and guessing. How about any codes or CEL.
Old 11-13-2009, 07:57 AM   #8
Crmzendrgone's Avatar
Crmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant futureCrmzendrgone has a brilliant future
I agree with what everyone else is saying about the fuel, I would look at the fuel delivery system all of it and see what is happening.
Old 11-13-2009, 03:02 PM   #9
RyanDL's Avatar
thanks for the replies i try a fuel pressure test and go from there
what starts with a F and ends with a K ? silverhairdeere Off-Topic 6 09-11-2009 11:43 PM
99 GMC starts then dies Bulldog187th GMC Truck Forum 7 08-21-2009 07:13 PM
Sometime it starts sometime NOT! cchambers Chevy Truck Forum 3 03-24-2008 09:04 AM
5.7L.Starts won't Run Vetteuser GMC Truck Forum 2 08-23-2007 07:43 AM
starts/runs with no key 72'CaminoKid Other Trucks 5 09-14-2006 10:31 PM
