Results 1 to 7 of 7
Thread: 1998 gmc 454 hard starting question?
    Dec 2009
    4
    Im new to the site and was wondering if anyone else has had the same problem as me and found a fix for it. I have a 1998 gmc 2500 with the 454 in it. I only drive it around 4 times a month and it sits in a heated garage. It will always start fine just seems like after its warm and i shut it off it takes a little more cranking to get it started agian then it should. Maybe 4-5 seconds before it starts. It also idles a little ruff and gets about 9 miles to the gallon. It has 107,000 on the clock. Truck has newer wires, plugs, fuel,and air filter within 8,000 miles but still same problem. Any help would be much much appreciated, love the truck just hate the starting problem!!!
    Nov 2009
    winchester, va
    4,173
    Welcome aboard bowtiekilr.Take it to a shop and have the timing checked. 96 and newer uses a scan tool to time. regular timing light wont work. replace coolant temperature switch.
    Dec 2009
    4
    coolant temp switch? Why would that take excessive cranking? Hate to take it to a shop they are usually expensive. I was wondering if the fuel pressure regulater is letting fuel leak into the engine after it runs, thus flooding it? Maybe? just seems like when you try to start it cranks like a flooded carbed engine
    Mar 2008
    N.Y.
    10,865
    Blog Entries
    1
    check the voltage reading on the o2 sensor with a scan tool and see if it is marginal
    Dec 2009
    4
    I just pulled the plugs and they are clean look pretty much new. I also regapped the plugs from 60 to 40 thous to see if it cleans the idle up a little. how exactly do you check a ox sensor? Im not getting a check engine code. truck did it again, started right up drove it for 20 min then it sat in the cold 30 deg weather then when i tried to start it extensive cranking again before it started about 4-5 seconds before it started again.
    hotrodpc's Avatar
    Jul 2008
    Moore, OK
    7,277
    Quote Originally Posted by bowtiekilr View Post
    Just something to try cuz its cheap, try a bottle of Heet in your gas tank. It should dry up any water you might have in the line and freezing. With that big of a tank it may take 2 bottles, just read the directions and use it as directed.
    85 Sierra Classic K1500
    85 Silverado K10
    84 Silverado C20
  7. #7
    Dec 2009
    4
    I know its not bad gas because its been doing this for about a year now, but thanks for the help!
  1. Hard Starting on a 98 K3500 7.4L
    By gerth21 in forum GMC Truck Forum
    Last Post: 08-30-2009, 03:28 PM
  2. hard starting denali
    By aolson in forum GMC Truck Forum
    Last Post: 08-20-2009, 12:11 PM
  3. 89 CK1500 PU 4x4 hard starting
    By mudd_jumper in forum Chevy Truck Forum
    Last Post: 10-18-2008, 02:50 PM
  4. Hard starting problem.
    By mdj21 in forum Toyota Truck Forum
    Last Post: 05-16-2008, 05:41 AM
  5. 7.4L Hard Starting
    By elkfool in forum Chevy Truck Forum
    Last Post: 12-31-2006, 10:02 AM
