Results 1 to 8 of 8
Thread: 1991 2500 gmc running to rich
    Junior Member modracer's Avatar
    Apr 2010
    9
    hi
    my buddys got a 1991 2500 gmc with the 5.7 350 in it. the truck right now runs like a peice of **** its running way to rich, in order to start it you have to hold it to the floor and it will take a few seconds to rev up and it will only run right high rpm's between 3000 rpms and 4000 i know thats kinda high to be reving it but its the only way it will run any thing below that it sputters and just blows out black smoke. we have tryed new plugs, wires, cap, new coil, just little stuff. i noticed when you crank it over not touching the trottle it sprays alot of fule in to it then you give it trottle and it just becomes like this little spray. i dont know to much about the whole tbi system so anyone who can help me out that would be great.
    thanks
    Senior Member silverhairdeere's Avatar
    Feb 2008
    land between the lakes tn
    1,831
    i would say your injectors are really gummed up , or your fuel pressure is really high , try some seafoam in the gas tank first , and post back to us .
    SHD
    1989 GMC 1500 (PROJECT CHEAP TRUCK)
    Mar 2009
    south west virginia
    298
    have you checked for codes is check engine light on something is calling for fuel when it should not be sometimes on these early models you can take the battery cables off for about 15 minutes put them back start it up allow a few minutes for the computer to reset and it's allright if that don't work you need to hook it up to a scanner other wize you can spend alot of money and still have your problem.
    Senior Member Towtruck's Avatar
    Aug 2009
    Ft.liqourdale, FL.
    161
    Check the fuel pressure regulator that is built into the TBI they are known to go bad and dump to much fuel into the engine. There should be a rebuild kit for the regulator at your local auto parts store
    ASHES TO ASHES, DUST TO DUST, IF IT WEREN'T FOR CHEVY'S MY TOOLS WOULD RUST
    Jan 2010
    Iowa
    1,746
    sounds like you have a temp sensor teling your computer that its -35 and the tbi is dumping extra fuel to compensate
    Apr 2010
    9
    where abouts is this temp sencor?
    thanks kyle.m
  7. #7
    Jan 2010
    Iowa
    1,746
    I believe it is in the coolant passage at the front of the manifold near the water neck. if it is bad it will do exactly what your talking about.
  8. #8
    Full Member tjrettig44's Avatar
    Mar 2010
    12
    I had the same problem on my 91 Gmc Sierra I ended up replacing the Throttle Positions Sensor(TPS) and it fixed mt problem!
  1. Chevy running like it's too rich
    By semocoachworks in forum Chevy Truck Forum
    Last Post: 03-09-2010, 07:25 PM
  2. 1991 K2500 fuel pump keeps running
    By wamullins in forum GMC Truck Forum
    Last Post: 10-20-2009, 04:45 PM
  3. Bad Gas Mileage, Running too Rich???
    By bigdogg1973 in forum Mazda Truck Forum
    Last Post: 09-13-2009, 08:57 PM
  4. TBI running rich
    By 1BigAmerican in forum Chevy Truck Forum
    Last Post: 11-04-2008, 08:27 AM
  5. running rich
    By vanhal in forum Chevy Truck Forum
    Last Post: 12-20-2005, 05:02 PM
