Old 01-16-2005, 01:41 PM   #1
Hollywoodk3 is on a distinguished road
Angry transmission help please
Hi I am new here. I just bought a '78 GMC truck and the transmission is acting funny. I have changed the fluid,filter and modulater valve. It still won't change automaticly but I can shift it manually. It dosen't slip when in third but if I come to a stop I have to do it all over again. Can someone help me please. Thanks.
Hollywoodk3 is offline   Reply With Quote
Old 01-19-2005, 12:13 AM   #2
Goofball1984 is on a distinguished road
Sounds like your torque converter might be the culprit. You might want to pick up a Chilton's and read up on it. Also,.. grab the make and model of the tranny and look it up on the net independent of the truck for research. I personally just bought an 87 sierra that has not run for two years. It is a manual like my 94 Z28. I do not have as much experience with auto's. However, it does not sound like linkages, seals, bearings, etc. are fubarred due to the ability to change manually; so check out the torque converter.
Goofball1984 is offline   Reply With Quote
Old 01-19-2005, 06:42 PM   #3
Thanks man I'll do it.
Old 02-11-2005, 07:31 AM   #4
chevynut is on a distinguished road
A to Z Transmission Exchange
Your problem can be one of two things first the easiest,check vac.at the mod. valve while engine running,if ok,it will be the govenor gear stripped orgov. valve sticking,...for sure
chevynut is offline   Reply With Quote
Old 09-05-2005, 11:58 PM   #5
silvervortek200 is on a distinguished road
there is a cable going from the throttle body to the tranny this is called a TV cable.
It helps control shift points and tells the tranny when to shift. This cable may have broke i would check that first.
its usually right beside the throttle cable on the throttle body. When you pull the end of the cable it should come out about 2 inches ans spring back in when released/its real easy to pull cable there isint much tension on it.
silvervortek200 is offline   Reply With Quote
Old 09-10-2005, 10:52 PM   #6
Banned
932500 is on a distinguished road
First off this is a 1978 truck we are talking about so it doesnt have a throttle body, it has a carb, secondly,the cable you are talking about wont affect it. If this is improperly installed it wouldnt shift in either manual or automatic, or would just shift real early do to lack of position signal to the transmission. Check the modulator valve. check the hose/line for vacuum leaks. If nothing found it is internal. The torque converter could not cause these symptoms either. Good luck
932500 is offline   Reply With Quote
Old 09-19-2005, 10:08 PM   #7
ok 93 2500, i didnt realise it was a 78 truck, i was thinking of the pre 99 trucks with fuel injection.
he changed fluid and filter i wonder if filter could have dropped down giving the valve body no oil pressure.[i suppose if that was the case the torque convertor would be starved for oil also.
I havent been around any of the pre 85 trucks with auro trans/ any we had were manual.
truck pics 03harley Ford Truck Forum 15 11-01-2004 12:39 PM
1996 Auto transmission question Blueoval Ford Truck Forum 0 09-18-2004 01:24 PM
