Results 1 to 4 of 4
Thread: 94 gmc 4x4 half ton rear end noise
    Jan 2011
    8
    Ok my truck is making a tinny nocking noise on decelration and under light throttle. It also seems to coincide with the trans downshifting so it does it at about 55-60,35-40,25-30. i have replaced the rear u joint and changed the rear end lube and added the friction modifiers as it is a limited slip. Any ideas
    Auto Banned
    Nov 2009
    Tupelo Ms.
    2,687
    Sounds like you might have a cracked flywheel(flexplate).
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,374
    Blog Entries
    2
    Check all good sound travels in the drive train could be a flex plate like JP said.
    Jan 2011
    8
    Yea well i popped the diff cover and to my cringing eyes the pinion gear is missin a few teeth and the ring gear has a few chipped. Its a ******* trying to find a 3:73 rear end in lower michigan....
  1. Rear end noise? Like a grinding noise.
    By markparks1 in forum GMC Truck Forum
    Last Post: 06-17-2010, 10:20 PM
  2. '97 gmc rear end noise
    By dieguy66 in forum GMC Truck Forum
    Last Post: 03-30-2010, 01:07 PM
  3. rear end noise
    By md47 in forum GMC Truck Forum
    Last Post: 12-04-2009, 07:44 AM
  4. 93' GMC Rear end noise
    By Nitroball in forum Chevy Truck Forum
    Last Post: 08-09-2009, 12:08 AM
  5. Rear end noise
    By hotdawg23 in forum Dodge Truck Forum
    Last Post: 07-29-2009, 06:42 PM
