Results 1 to 6 of 6
Thread: 92 GMC Sierra c1500 blowing white smoke
    Aug 2010
    8
    When ever the truck is sitting and has cools down when I start it there is a puff of white smoke that comes out of the tail pipe. It's a 1992 Sierra c1500 GMC with 169,000 miles on it. Is this puff of smoke burning oil or to much gas? I do have to put in about a qt of oil by the time I have a oil change evey 3 months.
    Senior Member c15004ever's Avatar
    Apr 2011
    Ft Campbell, KY
    84
    im no expert, but it sounds like your valve seals are no good. Common in these trucks around that many miles, my iroc-z does the same thing. Maybe someone else can explain it better
    Apr 2011
    3
    My '93 has 134,000 miles with a 4.3L and it does the same thing.Valve stem seals are gone. I just watch the oil level and try not to start it in front of a crowd.
    Nov 2006
    Houston,Texas
    6,929
    The seals can be replaced without taking off the heads talk to some local tech.
    http://i961.photobucket.com/albums/ae98/falken86/dadnew-1.jpg
    Mar 2011
    Beaumont,Texas
    30
    In my experiance , white smoke usualy means water vapor?
    Feb 2008
    Buena Park, CA
    50
    My 92 K1500 was doing the same thing. White smoke at startup and it went away after it warmed up. My got progressively worse over sevearl months until it was blowing white smoke almost all of the time. The truck is an extra vehicle that I only drive once in a while. Keep any eye on your coolant overflow tank. The level should remain failr constant. If not, you've got a leak.
    I tried replacing the head gaskets, but it continued to blow white smoke. I pulled them a second time and took them to a local shop. The diagnosis was a cracked head. They sold me a rebuilts set for a very fair price. The owner gave me a long list of things to do when putting it back together. It's been running great ever since.
  1. white or blue smoke at start up every once in a while
    By rich7732 in forum Chevy Truck Forum
    Last Post: 01-08-2011, 08:05 PM
  2. white smoke
    By frankied1987 in forum Chevy Truck Forum
    Last Post: 07-06-2010, 04:39 PM
  3. White Smoke? 1993 Mazda B2200
    By itoyota in forum Mazda Truck Forum
    Last Post: 06-25-2010, 01:37 PM
  4. truck blowing black smoke
    By Lucys truck in forum Dodge Truck Forum
    Last Post: 09-01-2007, 10:57 AM
  5. white smoke on cold start
    By truck067 in forum Dodge Truck Forum
    Last Post: 04-08-2007, 10:41 PM
Tags for this Thread
