Results 1 to 6 of 6
Thread: 95 gmc turns over but wont start
    Senior Member asifford5's Avatar
    Dec 2010
    Woodland CA
    67
    My friend got into his truck (95 gmc k1500 z71 with 350 v8) this morning and turned the key and it just clicked. Jump started and nothing. Came back after school and jump stared it with better cables and it started right up. Let it run a while and disconnected the cable. Tried to start again. It turned over but wont start. Jump started it again and it started. Disconnected the battery to test alternator and it died. Tried to jump it again and wouldn’t even start with cables. Put a new battery in it and still cant get it to start. Poured gas into throttle body and still wouldn’t start. Checked for spark and no spark. We have power into ignition coil but not out. Replaced it and still won’t start. so we gave up for thee night. Any suggestions will be greatly appreciated. thanks.
    1990 GMC K1500 4x4 SB 350 (daily driver)
    1988 Chevy V-20 Scottsdale Suburban 4x4 SB 350 (project)
    Apr 2011
    Tennessee
    211
    check the icm in the distributor its what sends signal to the coil to fire and injectors to pulse. they are pretty cheap to replace
    Dec 2010
    Woodland CA
    67
    What is the icm? I can't find anything on it in my Haynes guide
    Apr 2011
    Tennessee
    211
    this is the icm
    another thing check all the grounds and make sure they are all clean
    Attached Images Attached Images
    Dec 2010
    Woodland CA
    67
    thanks for the help. we replaced the icm and it fired right up
    Apr 2011
    Tennessee
    211
    no problem nice to hear it fixed your problem
  1. 97 yukon 5.7 will not start but turns over
    By 92chevywt in forum Chevy Truck Forum
    Last Post: 11-07-2010, 10:41 PM
  2. engine turns over won't start
    By fborng in forum Chevy Truck Forum
    Last Post: 11-01-2010, 04:04 PM
  3. 97 5.7 liter turns over wont start
    By swag72 in forum Chevy Truck Forum
    Last Post: 06-16-2010, 04:14 PM
  4. 94 S-10 wont start
    By GM4GOOD in forum Chevy Truck Forum
    Last Post: 01-05-2010, 10:49 AM
  5. Wont start
    By blue cobra 60 in forum Chevy Truck Forum
    Last Post: 10-18-2006, 09:24 PM
