Results 1 to 6 of 6
Thread: 1988-94 Chevy/GMC steering column
    Senior Member asifford5's Avatar
    Dec 2010
    Woodland CA
    67
    can anyone get me a diagram on how the steering goes toggeater???
    1990 GMC K1500 4x4 SB 350 (daily driver)
    1988 Chevy V-20 Scottsdale Suburban 4x4 SB 350 (project)
    Moderator
    Jul 2011
    Central Oklahoma
    5,338
    Are you needing the inside part or the whole column?
    Dec 2010
    Woodland CA
    67
    The inside part. I can't figure out why the key won't spring back when you start it? do all the wires have to be plugged in? I haven't put it all together yet because I'm trying to make the key spring back
    Moderator
    Jul 2011
    Central Oklahoma
    5,338
    There is a rod that is turn by the key switch that runs down to another switch inside that its spring loaded thats what makes the key return or snap back. Make sure that rod is run down into the ignition switch lower on the column. If that don't work then the spring inside that ignition switch is broke. WHat you have up top is a key switch the actual ignition switch is lower on the column about half way down you should see some wires plugged in.
    Dec 2010
    Woodland CA
    67
    thanks for your help. we got it fixed. the wasnt attached to the rod and the rod wasnt it the track its supposed to be in.
    Moderator
    Jul 2011
    Central Oklahoma
    5,338
    Good deal.
  1. 1988 chevy steering wheel wobble.
    By 2chevy in forum Chevy Truck Forum
    Last Post: 08-16-2011, 02:41 PM
  2. will a steering column from a 88 fit a 77- Chevy
    By roastadore in forum Chevy Truck Forum
    Last Post: 05-14-2011, 02:35 AM
  3. Diagram of steering column for 1989 Chevy Silverado 2500
    By Mickey Z in forum Chevy Truck Forum
    Last Post: 11-15-2010, 06:49 AM
  4. 89 Chevy steering column help
    By notyoman in forum Chevy Truck Forum
    Last Post: 10-09-2010, 09:54 PM
  5. 1989 Chevy C1500 Steering column question
    By shawn_huk in forum Chevy Truck Forum
    Last Post: 05-20-2008, 01:30 AM
