Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: 4 wheel drive shaking
    Nov 2011
    4
    I have 1995 GMC 1500 4x4 5.7L. When i drive it in two wheel drive everything runs smoothly. When I engage it into 4 wheel drive and accelerate my front end shakes. It feels like it is coming from the front axle. What should I do first to eliminate possible problems before I go out and spend money on things i might not need to buy?
    Senior Member Billselfjr's Avatar
    Mar 2011
    W.V.
    183
    go under the front and start shaking stuff is the cheapest thing i can tell you to do but if you have independent front end then check boots for cracks if you see bad boot may have bad joint you can also jack it up put in 4 lo move tire forward and backwards to see if slack in joint .if no bad joints then check front drive shaft for bad universal joint. unless the front has been in damage then it should be one or the other
    A day you don't learn something is a day wasted
    Dec 2007
    1,645
    ^^^^^^ What he says. Check the universal joints in the front driveshaft and also the slip joint.
    Nov 2011
    4
    Well i went and test drove the truck, got it all warm and tried the 4 wheel drive out and guess what, it ran smoothly. I am not sure what it is, but next week I am going to order a new actuator for the tranfer case just to be on the safe side. There is supposed to be one on the front diff and one on the T-case. Is this the right info? I just don't know why one day it would do this and another day it didn't...confused...by the way, thanks for all your guys help.
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,466
    Blog Entries
    2
    Best to lock all in run some few times a month... turning wheels ect. Things will lock up with rust ect.
    Mar 2008
    N.Y.
    10,838
    Blog Entries
    1
    make sure the spline for the front driveshaft is moving freely
  7. #7
    Nov 2011
    4
    Che cked the spline on the front drive shaft and the universal joints and everything looks and feels like they are in good working condition. The cv joint boots look like they are brand new. Anyother suggestions of what it could be?
  8. #8
    Mar 2011
    W.V.
    183
    the drive shaft may be out of balance or bent cv shaft may be bent. do you notice it more when you turn ,apply brakes or at certain speed??
    also do you notice a little shake when out of 4 wheel or anything that seem like a wheel out of balance..?
  9. #9
    Nov 2011
    4
    I only noticed the shaking when I accelerated or whenever my foot was on the gas. When I am out of 4 wheel drive everything is smooth feeling. I am going to service the front diff and the rear axle, just for maintanence purposes.
  10. #10
    Mar 2008
    N.Y.
    10,838
    Blog Entries
    1
    if you are on dry roads it will give it a funny feeling.....front tires pull while the back push...how is it on a slippery surface?
  1. 4 wheel drive problems in 2 wheel drive
    By ElmerJ in forum Chevy Truck Forum
    Last Post: 09-20-2011, 07:41 PM
  2. 4 wheel drive problems in 2 wheel drive
    Last Post: 09-18-2011, 08:38 AM
  3. Can I 4-wheel drive?
    By celinaman060 in forum Chevy Truck Forum
    Last Post: 11-23-2009, 02:28 PM
  4. 2 wheel drive to 4 wheel conversion
    By frank3ks in forum 4x4 trucks / off road
    Last Post: 03-31-2008, 09:30 PM
  5. Wheel Question on my 4 wheel drive???????????????
    By 92BlueZ71 in forum Chevy Truck Forum
    Last Post: 03-19-2007, 04:06 PM
Tags for this Thread
