| Junior Member Join Date: Mar 2005
| 2000 Gmc I have a 2000 1/2 ton pickup it is or I think in excellent condition, 60,000 miles never any problems,but today while I was driving it I shut it off for about ten minutes, restarted it it run for about two seconds and it won't start now, I cked the fire and it is getting fire to the plugs, I think it is fuel related, I found a fuel pump relay but couldn't find the fuse that supplies the power to the fuel pump. Could someone tell me where the fuse is located or if it even has one or what do you think could be wrong with it |
| Full Member Join Date: Feb 2005
| have you changed th fuel filter,most you normally get is 50,000 mi. on them |
| Full Member Join Date: Sep 2005 Location: georgia
| sounds like the fuel pump to me but there was a problem with loose wires where the wires go through the tank. On the drivers side there is a small triangular panel you will see once you have door open fully and your standing outside truck/ there is fuses there too. but the relay is probably on the fuse box inside the negine campartment if not on the older trucks the relay was next to the fire wall on the right hand side// Open the hook have someone turn on and off an on the ignition// you should hear the relay click. |
| 2000 Chevy tranny shifting hard | tdbp76 | Chevy Truck Forum | 5 | 04-22-2007 09:48 PM |
| 2000 Silverado - "Piston Slap" | Snowdooer | Chevy Truck Forum | 20 | 11-19-2006 10:23 AM |
| 2000 Tahoe Gas Gauge | neo | Chevy Truck Forum | 1 | 03-13-2005 02:45 PM |
| power door locks 2000 Tahoe & 94k1500 | neo | Chevy Truck Forum | 0 | 03-12-2005 08:22 AM |
| 2000 tahoe ? | Dsmolj | Chevy Truck Forum | 0 | 12-19-2004 03:42 PM |
