Results 1 to 2 of 2
Thread: 2006 Sierra 4.3 1500 ignition problem
    Newbie
    Jun 2012
    1
    Question 2006 Sierra 4.3 1500 ignition problem
    Today I went to start my truck and it just clicked. The lights in the instrument panel did not come on and the truck will not start. I wiggled the key a little and that made all the lights come on but still a click when I try to start it. Played with it a bit more and noticed a noise comming from dash like a tiny motor resetting the gauges. Them with the key out the dash lights come on and so did the cab light and the clock. They went outand now even the warning bells won't work with the key in and the door open. Very puzzling, tested the batt it is ok. Ignition switch?
    chevychase's Avatar
    Oct 2010
    truck forum .org
    21,392
    Blog Entries
    2
    will either be tumbler for key or ignition switch .
    Switch is located on down inside column.
    Here is info how to change tumbler How Do I Change the Ignition Cylinder in a 2005 GMC Sierra Truck? | eHow.com
    Here is info how to test ignition switch GM truck bad ign. switch
    Just click on red links if i find info how to change switch will post.
  1. 2006 Sierra
    By dls56 in forum GMC Truck Forum
    Last Post: 01-24-2014, 01:45 PM
  2. starting problem - 2006 GMC Sierra 1500
    By edapeman in forum GMC Truck Forum
    Last Post: 01-18-2011, 12:54 PM
  3. 2006 GMC sierra Z71 4x4
    By canadianGMC in forum GMC Truck Forum
    Last Post: 02-20-2010, 09:49 AM
  4. 89 sierra 1500 sl wiring problem
    By batmanwb in forum GMC Truck Forum
    Last Post: 08-06-2008, 12:57 PM
  5. 90 gmc sierra 1500 electrical problem
    By ducorse in forum GMC Truck Forum
    Last Post: 11-28-2006, 01:14 AM
