Old 06-17-2005, 07:01 PM   #1
sierra 4x4 is on a distinguished road
Angry Please Help!!! Problems engaging 4WD
I have a 95 GMC Sierra 2500 4x4, and it will not engage the front wheels...I am guessing that the auto hubs are not locking. I checked the fuse, and it was blown, so I replaced it, and it blew the new fuse also. If anyone know what the problem is and/or how to fix it please let me know.
Thanks.
sierra 4x4 is offline   Reply With Quote
Old 06-17-2005, 10:51 PM   #2
Ford4x4Chik27's Avatar
Ford4x4Chik27 is just really niceFord4x4Chik27 is just really niceFord4x4Chik27 is just really niceFord4x4Chik27 is just really nice
Crossed wires? It sounds to me like you have a short somewhere...the trick is finding it
'93 Isuzu Amigo, Toyota Axles/Tcase/Drivelines, 35" MTR's. '01 Pathy, DD.
A fact of life: After Monday and Tuesday, even the calendar says W T F.....
Old 06-18-2005, 09:03 AM   #3
marble75 is on a distinguished road
mabye the acuator motor has a short thats the motor that locks the 4wheel drive i think u might check this and also there are several harneses on the trany that are conected to this . u might start there
marble75 is offline   Reply With Quote
Old 08-20-2005, 06:21 PM   #4
Ozymandias is on a distinguished road
I can tell you what it is... there is an actuator motor in the front Dif... this thing goes out on a whim.. you can pick up a new one from autozone for like $125 if i remember correctly... however if you do this you're self, there is a new extra wire on the new one, this replaces the temp sensor that was on the factory actuator. ; )
Ozymandias is offline   Reply With Quote
Old 08-26-2005, 09:51 PM   #5
67redbowtie is on a distinguished road
try looking on the side of the front diff.You should have an acuator there w/a wire harness conected to it, I had the same proplem on mine and if you dont use your 4 wheel drive often it will lock in and not engage, what I did was take mine out and pull out the acuator with channel locks while a friend ennergized it in the cab repeated several times untill it was free. After that I will every now n then I will shift into 4 wheel drive even at a stop to keep it in action..........
67redbowtie is offline   Reply With Quote
Old 10-07-2005, 03:19 PM   #6
Kennyray's Avatar
Kennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud ofKennyray has much to be proud of
On my 95 serria it was the switch on the tranfer case. According to a mech friend of mine they changed the actuator in 96 and started having problems then, so he put a 95 actuator on his 96. Just my 2 cents.
Kennyray is offline   Reply With Quote
Old 10-07-2005, 09:21 PM   #7
chevyguy's Avatar
O.K. here we go. Sinple unplug the fron diff actuator and engange the 4 wheel drive (press the button) if it blows the fuse still it is the actuator, if not plug the actuator in and unplug the transfer case and try it again. These are simple chacks to verify which component is bad. Otherwise your just playing parts changing roulette.
Old 10-09-2005, 03:18 PM   #8
Itstali25's Avatar
Itstali25 is on a distinguished road
lol parts changing roulette..........sorry i thought that was funny, i've never heard it before lol
http://www.cardomain.com/ride/644045
Trucks are just cars when they grow up!!!
If your gunna get a truck....Get a TRUCK!!
Itstali25 is offline   Reply With Quote
Old 10-09-2005, 10:27 PM   #9
chevyguy's Avatar
Alot of people do it when they dont properly diagnose the problem and end up replacing alot of good parts
Electric window problems maynard22 Mazda Truck Forum 0 04-15-2005 06:27 AM
allison transmission problems? Sandy C GMC Truck Forum 2 03-17-2005 05:45 AM
carb problems F150on40's Ford Truck Forum 3 01-05-2005 06:52 PM
power door unlock problems chris ss Chevy Truck Forum 1 12-23-2004 09:39 PM
truck problems bigcharles Ford Truck Forum 1 11-01-2004 12:04 PM
