| Junior Member Join Date: Nov 2005
| 93 k2500 4 X 4 with TBI problem I have a 93 2500 4 X 4 truck with a plow on it..........it had a 350 in it and i pulled it out because it was really worn down with 370 000klms on it. i bought a crate engine 305 and put it in with everything hooked ready to go. The engine turns over the fuel pump presurizes and there is fuel at the throttle body just before the two injectors. when it turns over there is no fuel spittin out of the two fuel injectors. when fuel from a bottle is thrown in the throttle body it starts for a second. ive come down to that there is no pulsating at the injectors. My question to u experts out there how do i determine whether it is electrical or whether it is the injectors. PLEASE help as i want my truck running IF YOU have any suggestions please offer if the suggestions are about electrical components please explain carefully as im not really good with a voltmeter or other electrical things. THANX |
| Check fuel pressure. Could be a regulator, Thats a start.
| Senior Member Join Date: Oct 2005
| Could also be faulty injectors, before you jump to this conclusion though make sure you have everything hooked up. Is your wiring for your injectors and everything else hooked up? |
| Diesel problem | jgn | Dodge Truck Forum | 3 | 02-24-2010 07:37 PM |
| chevy s10 fuel injector problem... | rrodriguez190 | Chevy Truck Forum | 8 | 10-29-2005 11:23 PM |
| Problem with 88 gmc 1 ton | jrsrcvry | GMC Truck Forum | 6 | 10-24-2005 10:45 AM |
| 99 Suburban Idle Problem | Myles | Chevy Truck Forum | 3 | 08-05-2005 09:24 PM |
| 02 S10 problem | 84ranger | Chevy Truck Forum | 3 | 05-20-2005 07:28 PM |
