Old 01-01-2006, 09:18 PM   #1
seadog is on a distinguished road
Question 1998 GMC Suburban Brakes
Hi gang, I am a newbie and I may screw up while trying to get the info that I am looking for, so please bare with me.
I have a 1998 GMC Suburban 1/2 ton. I have 31 x 10.5 x15 tires mounted on 10" wide custom wheels. I am wanting to convert my brake system over to 4 wheel disc brakes. I currently have front disc and rear drum brakes. Also I am having trouble with front rotor warpage. Help!!. Do any of you have any suggestions for the conversion and the warpage problems
Thanks
seadog is offline   Reply With Quote
Old 01-02-2006, 01:33 AM   #2
Senior Member++
DodgeChick's Avatar
DodgeChick is just really niceDodgeChick is just really niceDodgeChick is just really niceDodgeChick is just really nice
Welcome to the forum!
Ive moved this to the GMC section for you as you'll get more hits there
2002 Patriot Blue Ram 1500 4x4 in the process of some mods
*****Voted Best Truck on HGS*****
Silly boys!! Trucks are for girls!!!
"Grab Life By The Horns"
DodgeChick is offline   Reply With Quote
Old 01-02-2006, 09:57 PM   #3
hotrod69's Avatar
hotrod69 is on a distinguished road
Welcome To The Forum. Do U Keep Buying New Rotors And If So Are U Getting The Cheapest U Can Find? This May Be A Mistake, Another Problem Is The Rear Drums May Not Be Adjusted Correctly So That They Are Not Doing Their Part Of The Braking Thus Over Loading The Front Brakes. If U Are Looking To Do A Convertion To 4 W Disc Look For A Kit That Has The Master Cylender, Poportioning Vavle And All The Hardwear Necessary To Do The Convertion And Most Important Of All The Instrutions On How To Install And Adjust The Rear Discs Properly, I Am Assuming That Ther Will Be A Parking Brake That Is Apart Of The Rear Discs. This Means That It Is Very Important That It Is Adjusted Or The Same Thing Will Keep Happening To The Front Discs. If U Have More Questions About The Convertion Dont Be Afraid To Ask, I Have Done A Few Convertions For Friends With No Complaints Yet, Ford And Chevy.
HOTROD
NOTHING LIKE DRIVING A CHEVY
hotrod69 is offline   Reply With Quote
Old 01-13-2006, 08:59 PM   #4
Thumbs up 98 GMC Suburban Brakes
Can you reccommend a conversion kit and the type of disc to apply to the front.
Seadog
Old 01-15-2006, 10:45 AM   #5
gmtech has a spectacular aura aboutgmtech has a spectacular aura aboutgmtech has a spectacular aura about
If you want to keep the factory brakes there is a bulliten which addresses your concern of premature brake wear of front pads. The bulliten has you change to a new design pads and rear shoes and also replace the brake proportioning valve which puts more braking effort on the rear brakes. This repair has worked on stock vehicles that I have done it on with customers which tow alot.
Old 01-15-2006, 08:28 PM   #6
gmtech
Can you give me the bulletin # so that I might be able to get it from the local GMC dealer?
seadog
Old 01-16-2006, 05:12 PM   #7
#99-05-24-001A This is the bulliten number and these are the vehicles it pertains to Brake Lead/Pull and Front Brake Wear (Replace Front Brake Pads And/Or Rear Brake Shoes) 1992-1999 Chevrolet and GMC C/K Cab Chassis, Crew Cab, and Pickup Models with Power Brakes (RPO JB8)
1992-99 Chevrolet and GMC C/K Suburban Models with 8600# GVW (RPO C6P)
1996-2000 Chevrolet and GMC G Vans with Power Brakes (RPO JD7 & JB8) and GVW's of 7,700# up to 9,500# (RPO's C3F, C6P, & E23)
I hope this helps.
Old 01-17-2006, 08:32 PM   #8
Thumbs up gmtech
Thanks for the info. This will help greatly.
seadog
97 Siverado Brakes chilligolf59 Chevy Truck Forum 4 01-06-2006 06:20 PM
brakes overheat bigtime but i replaced everything jazzzmonky Ford Truck Forum 8 11-13-2005 11:55 AM
73-87 Chevy Suburban 2wd Lift Kit Question JIM Chevy Truck Forum 0 05-27-2005 10:07 PM
Sign Truck Loses Brakes; Crashes Into 'Sinking Ship' Garage In Seattle (KOMO) trucknews Truck News (headlines) 0 03-20-2005 07:30 PM
Biggest tires on a stock 93 Suburban 93 Burbon Chevy Truck Forum 2 03-20-2005 09:35 AM
