| Junior Member Join Date: Jan 2006
| rusted brake lines workin on a 98 GMC sonoma with rusted brake lines and was wondering do i have to replace the line flare nut to flare nut or just the rusted section or can i replace the whole thing with with some sort of flex hose. |
| Replace the whole thing with good replacement part, DO NOT USE FLEXIBLE LINE THERE. If it isnt rated for the load you might be in for a shock the first time you try to stop.
| we've replaced bjust the bad section of lines before, just make sure you get all the bad out
| If you just replace the bad section you will need to remove the line to get the flaring tool on and buy new ends for it anyway, Seems like a waste to go thru all that for old lines.
| true, but if money is as issue..... i dont know whether it is for you or not, but if it is, it can be reapaired and not need all new lines
| If the line is rusted then by moving it and twisting it, in order to cut and flare it, the line may break in another place. I know money is tight for some folks but if you hit someone else then you'll have bigger problems than a $20.00 brake line. There are hydraulic flex hoses that can be used and there are several places that can make them as well (O-Rilley comes to mind). I normally dont replace anything in my vehicle unless it is with something comparable to the original. |
| Full Member Join Date: Feb 2006 Location: Indiana
| I agree with the change of the entire line here. Replacing just the bad section may cause breaking problems on some other part of the line. Don't forget to bleed the brake system after replacement. |
| Why replace half a rusted line anyhow. Just get new and dont worry about it for a long time.
| Hayes Lemmerz International, Inc. Wheel Groups Announce Expansion of Their Product Lines to Include Aluminum Wheels for (The Auto Channel) | trucknews | Truck News (headlines) | 0 | 09-21-2005 11:30 PM |
| Hayes Lemmerz International, Inc. Wheel Groups Announce Expansion of Their Product Lines to Include Aluminum Wheels for (PR Newswire via Yahoo! Finance) | trucknews | Truck News (headlines) | 0 | 09-21-2005 09:30 AM |
| Brake control question | katiescat | Dodge Truck Forum | 6 | 08-19-2005 11:37 AM |
| brake booster | 72'CaminoKid | Chevy Truck Forum | 0 | 08-12-2005 09:08 PM |
| Truck takes out utility pole, power lines (WFSB 3) | trucknews | Truck News (headlines) | 0 | 05-03-2005 09:30 AM |
