| Senior Member Join Date: Feb 2006 Location: South Dakota
| GMC sierra. 4x4 differential question I have a 1996 GMC sierra 1500 4x4. I have a stock rear end and i'm wondering if anybody knows the stock gear ratio and how I can tell if it is a dana 60 or a Chevy rear end? Or what i can check to see what it is. |
| More than likely it is a stock gm 10 bolt. I know they used to have a sticker in the glove box that had what the gear ratio was. If not it is on the door with the vin number and gvwr. As for what type of rearend it is there should be a metal tag on the differential housing or axle tube that'll give you more information on it
| it is a 10 bolt GM. I can't seem to find what the ratio is set at. Any other ideas? I guess i might be able to count turns after i mark the tire. Also, does anyone know where i can get a lock for my diff? |
| Give me your vin number and I should be able to tell you the ratio. |
| Senior Member Join Date: Oct 2005 Location: NORTHERN CALIFORNIA
| Do U Want A Locker Or A Limited Slip Posi Either Way Ther Are A Lot Of Places That U Can Get Them At Like Off Road Wharehouse, Summit, 4wheel Parts, And Many Other To Name A Few. Maybe Even Look At Your Local Rear End Shop They Might Be Able To Cut U A Good Deal On A Rebuilt Or Better
__________________ HOTROD NOTHING LIKE DRIVING A CHEVY |
| Senior Member Join Date: Mar 2005 Location: ontario, canada
| rear end ratio.s look in the glove box there are rpo codes for that truck if it says .....gt4 then you have 3.73 ..................gt5 ...................4.10 ..................g80 it is positraction also go to the search engine production codes on gm trucks it will give you a whole list of codes hope this will help you ..............................pete
__________________ I am gm all the way ....... black 98 Z71 3 door short box 5.7 |
| thanks. I got 3:73. GT4 My local shops don't carry anything. I would prefer an actual lock, but like a limited slip is better than nothing. If you guys know of somewhere i might be able to order something, let me know... |
| wellcome glad to help all the way from ontario canada
| thanks! Beats markin the tire and countin turns. |
| anybody know a website where i might be able to buy a lock? |
| GMC Sierra RPM Rising when Shifting gears Down | MarkL1 | GMC Truck Forum | 8 | 12-05-2006 07:24 PM |
| should I buy a 2000 Sierra with 4.8L | HuntinTruck | GMC Truck Forum | 6 | 02-13-2006 01:04 PM |
| 88 Sierra Radio Wiring | rsqured7 | GMC Truck Forum | 4 | 09-29-2005 09:12 PM |
| '01 Sierra HD Cutting Out | Tissy | GMC Truck Forum | 5 | 09-18-2005 11:07 PM |
| Four-wheeling in the Sierra: From mild to wild (Sierra Sun) | trucknews | Truck News (headlines) | 0 | 08-10-2005 07:30 AM |
