| Junior Member Join Date: Mar 2006
| Guys- New to the board and hoping yall got an answer for my question... Got a 01 Gmc Z71 and I have a serious problem... Ok- With the push button four wheel drive, I put it in Neutral, push the 4HI, the light blinks 4-5 times, stops blinking(as if it is in 4HI) But its not! The 4LO does work, but the 4Hi doesnt! Whats the deal? I took it to some shop and they said that a "gear" was not droppin down into some position so it wasnt not catching??? THIS MAKE SENSE? Another guy told me it could be as simple as a fuse or a bad sillinoid? The shop told me it would cost 1,000-1500 bucks to have it fixed!!! What do yall think it is? THANKS! |
| Senior Member Join Date: Nov 2005 Location: Grand Rapids, MI
| Try this: put the truck into neutral, push the 4L button (let it engage) and then the 4H. I've had mine "stick" before and this would "cure" it. Check the wiring behind the dash panel and below the truck for anything loose, too. Hopefully, it's something simple and cheap. |
| Cant be wiring if the light flashes.
| Junior Member Join Date: May 2006
| ive got a 2004 canyon, with push button 4x4, and i have the same problem, except mine wont go into 4LO, i am just as curious as you to know what the heck is going on. |
| it could be a vacum problem making your accuater stick, happened to my blazer, except mine wouldn't disengage.
| Well I would suspect a timing issue with the motor on the transfer case, or an actuator. My question is when you put int in the w range that appears to ork, havee you tested it to ensure it is actually engaged? i usually put a manual actuator on the front diff because i like to know for sure weather it is in or not.
| Senior Member Join Date: Feb 2006 Location: South Dakota
| just went throught the exact same symptions on my blazer and it was the actuator. I know they're different, but when my truck went out, it took a long time to go into 4 wheel drive. I replaced it before i lost 4wd, but my blazer just quite on me...i dunno.
__________________ '96 GMC 1500 Victory Red x-cab 4x4 Programmed 350 crying for a rebuild '88 IROC-Z Camaro 5.0 5speed t-tops stock...not for long '93 Escort GT 1.8 DOHC 127hp 5speed. Daily Driver/Beater |
| TCOMs First Tactical Aerostat System to Provide Surveillance On-the-Move (PR Web) | trucknews | Truck News (headlines) | 0 | 08-29-2005 01:30 AM |
| Penske Truck Leasing Introduces Fleet Insite System (TruckingInfo.com) | trucknews | Truck News (headlines) | 0 | 08-17-2005 01:30 AM |
| Penske Truck Leasing Introduces Fleet InSite(TM) System - A Low Cost, Web- Based Vehicle Tracking Solution for Private (The Auto Channel) | trucknews | Truck News (headlines) | 0 | 08-16-2005 03:30 PM |
| Penske Truck Leasing Introduces Fleet InSite(TM) System - A Low Cost, Web- Based Vehicle Tracking Solution for Private (PR Newswire via Yahoo! Finance) | trucknews | Truck News (headlines) | 0 | 08-16-2005 11:30 AM |
| German truck toll system finally launches (IT World) | trucknews | Truck News (headlines) | 0 | 01-03-2005 09:30 PM |
