| Junior Member Join Date: Dec 2005
| 06 Sierra trailer brakes help I just hooked up a brake controller on My 06 Sierra 2500HD. The light on the controller cames on but there are no brakes unless I do it manually. Is there a fuse somewhere that would control the power when I step on the brake petal? Thanks.. |
| Have you adjusted it properly. Also those things mostly work at certain angles. You cannot tilt them to far. When does the light come on?
| As soon as the trailer is plugged in the light glows green. When I go to level the sensor per the instructions the light is supposed to turn orange or red but it does not. The brakes engage with the manual slide on the controller but not when I step on the brake pedal. |
| There are 2 fuses a 25a stop lamp fuse under hood fuse block then it goes to the 10a veh chmsl fuse in the instrument panel fuse block assuming you hoocked it up factory to the connecto under dash left side? |
| Junior Member Join Date: Apr 2006
| I just hooked up a Prodigy brake controller on my '05 GMC and had to change the red wire in the connector harness which is the brake light signal. This is because GM changed their wiring in '03 and some of the brake controller manufacturers do not reflect this change. |
| should I buy a 2000 Sierra with 4.8L | HuntinTruck | GMC Truck Forum | 6 | 02-13-2006 12:04 PM |
| Electric trailer brakes | Bootlover | GMC Truck Forum | 2 | 02-10-2006 03:43 PM |
| Help with Hauling horse trailer PLEASE!! | stina3246 | Mazda Truck Forum | 13 | 12-12-2005 01:14 PM |
| Four-wheeling in the Sierra: From mild to wild (Sierra Sun) | trucknews | Truck News (headlines) | 0 | 08-10-2005 06:30 AM |
| Investigators find that logging truck had no brakes (New Bern Sun Journal) | trucknews | Truck News (headlines) | 0 | 03-24-2005 10:30 PM |
