Old 05-03-2006, 03:59 PM   #1
SMarlin40CL is on a distinguished road
Coolant Flush Problems
My truck ('99 Sierra) recently hit 100,000 miles so I underwent a coolant drain, flush, and replace. I purchased a Chiltons manuel a while back to assist me in the numerous processes to complete for 100,000 maintenance. After I began draining the coolant from the radiator (through the tube), it said to remove the drain plugs on the cylinder block. I located the place on my truck where the manuel said they would be, but on one side the cylinder block was blocked by other items and on the other side there was a sort of inward hex bolt looking thing, something that I did not have the tool to remove.
Does anyone know where these plugs are or are they even necessary to remove to preform a flush? Any assistance in this process would be greatly appreciated.
Thanks, Andrew
SMarlin40CL is offline   Reply With Quote
Old 05-03-2006, 06:12 PM   #2
chevyguy's Avatar
Yip thats them. Not really a requirement. i just pull the thermostat housing and run a hose thru ontil the water comes out clear.
USMC 92-96 USCG 98 to present
Old 05-03-2006, 06:20 PM   #3
you can remove the small stud on the one side you talked about. the oppisite side should have a sesor you need to remove.
i'd rather be hunting
Old 05-04-2006, 04:47 PM   #4
Thanks ya'll I appreciate it, but what kinda tool do you use to remove those bolts?
Old 05-05-2006, 05:49 AM   #5
i suggest getting a set of sockets with an allen wrench head on the end.
Old 05-05-2006, 12:24 PM   #6
chevyguy's Avatar
I spray the bolts with silicroil a few days prior to removing them. it halps them come right out.
Guy Problems Dakotah Off-Topic 46 05-06-2009 02:16 PM
1987 Silverado 350 TBI MAP sensor problems 87Silverado Chevy Truck Forum 3 03-27-2006 08:12 AM
4 Wheel Drive Problems 92BlueZ71 Chevy Truck Forum 7 03-12-2006 03:22 PM
Info for everyone with accel problems speadphreak Chevy Truck Forum 2 01-04-2006 06:24 PM
98 electric problems 98Z71 Chevy Truck Forum 4 08-20-2005 07:39 PM
