Old 05-08-2006, 09:50 AM   #1
72GMCSierra is on a distinguished road
Question Identifying Transmission
Hello,
Not sure if the auto tranny in the truck is stock or not so I don't want to go off the books. Does anyone know where I look on the transmission to identify it? The reason I ask is because I have to rebuild the 402 engine in the truck but I am thinking about replacing it with a 350 crate motor and I need to know if I can resuse the bellhousing, etc etc. Thanks in advance.
Patrick
72GMCSierra is offline   Reply With Quote
Old 05-08-2006, 10:02 AM   #2
Moderator
bradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to behold
look at the pan. if i remember right, there should be 16 or 17 bolts. correct me if im wrong someone. 17 bolts are the 750r without overdrive and the 16 is the 750r with overdrive. i believe that the 350 tranny is going to have 16 bolts on a fairly square pan. might want to make sure that is right before much of anything though. its been a couple years
Old 05-08-2006, 11:40 AM   #3
Thank you for the info. I was just thinking to myself though that if I swap out to a 350 I'll need to buy headers, intake, etc etc. Now I'm thinking it is better just to swap out the motor. Just was trying to save some gas. I guess I still have some planning to do. Thank you for the info because it is still good to know what I have.
Thanks,
Patrick
Old 05-08-2006, 12:02 PM   #4
Moderator
i do agree with you there. i priced a rebuild and turned around to price a new crate and they were close enough for me to spend the extra just to have a new block. but that is also turning my old block in for a core. wish the best of luck to you.
Old 05-08-2006, 01:34 PM   #5
Moderator
sorry, meant 700r tranny
Old 05-08-2006, 04:43 PM   #6
Moderator
If the pan is square it is a 700R, if the pan is square with one corner cut on the back end it is a 350. 400 pans look wierd, kinda hard to explain. If you can snap a picture of it we can tell you.
Old 05-10-2006, 10:05 AM   #7
lithopro is on a distinguished road
The Th400 pans
are shaped like the state of texas. I have one behind my 350 in a K2500.
lithopro is offline   Reply With Quote
Old 05-14-2006, 09:25 AM   #8
chevyguy's Avatar
Go to summits website and look up transmission. They have alot of pan gaskets and aftermarket pans pictured. Compare to your and there you have it.
Old 05-24-2006, 07:45 PM   #9
bowtieman is on a distinguished road
yes u can reuse the bell housing,the're the same from six cylinder to to a big block chev
bowtieman is offline   Reply With Quote
Old 05-25-2006, 10:26 AM   #10
chevyguy's Avatar
How many speeds? If it is a 3 speed then it sounds like you got a th400.
auto transmission won't shift and rpm& speed guages don't work gmcer GMC Truck Forum 13 05-04-2006 08:27 AM
transmission swap cap mowers Dodge Truck Forum 1 04-12-2006 05:53 PM
Transmission fluid?? Schrodes Ford Truck Forum 4 12-12-2005 02:52 PM
Transmission help damarr30 Dodge Truck Forum 2 10-30-2005 12:09 AM
Transmission Help Needed George911 Ford Truck Forum 7 08-02-2005 11:35 AM
