| Senior Member Join Date: Feb 2006 Location: South Dakota
| stainless steel oxidation What will fix the oxidation on stainless steel bed rails and caps? Seems like i've tried everything and i still can't get it off...
__________________ '96 GMC 1500 Victory Red x-cab 4x4 Programmed 350 crying for a rebuild '88 IROC-Z Camaro 5.0 5speed t-tops stock...not for long '93 Escort GT 1.8 DOHC 127hp 5speed. Daily Driver/Beater |
| ive used 000 steel wool before. if you decide to try it, remember KEEP IT WET. otherwise, it will scratch the heck out of it |
| I use 0000 steel wool. Never had an issue. I even use it on my windows to clean off all the garb. Make sure it is 4-0s though thats 0000. it is very fine and wont sctatch .
| Full Member Join Date: Feb 2006
| You might even try comet and some elbow grease and there are polishing compounds for stainless, much like rubbing compound used on oxidized paint. |
| Good point. i forgot about just using good old polishing compound.
| iv'e got the same problem, tried sos pads and got some small spots to shine. mabye the steel wool will work better. metal polish didn't work for me, i got some major build-up.
| i've trive the polish 0000 steel wool sounds like a good idea. I have some serious build up too...
| You can also put some Hot Sauce on it. try to get the hottest you can find. It might sound stupid but it works |
| Senior Member Join Date: Jul 2004 Location: Southern Missouri
| hmmm never heard the hot sauce thing, tell us how it turns out!!!
__________________ http://www.cardomain.com/ride/644045 Trucks are just cars when they grow up!!! If your gunna get a truck....Get a TRUCK!! |
| ive heard of someone using coke and aluminum foil before and ...... that it works good. i myself am too nervous on trying it |
| stainless rocker trim | awpratt | Chevy Truck Forum | 0 | 11-22-2005 07:40 AM |
| Truck Jackknifes, Drops Steel Coils On N.J. Turnpike (WNBC) | trucknews | Truck News (headlines) | 0 | 08-05-2005 05:30 PM |
| Truck knocks down Piraeus steel bridge (Kathimerini) | trucknews | Truck News (headlines) | 0 | 11-13-2004 05:30 AM |
