| Junior Member Join Date: May 2005
| programing door key remote 99 denali how do you program a new door key remote on a 99 denali???? thanks Roy |
| If it is the new body style truck which I'm not sure if it is or not it is easy. Hold the unlock button on the door and cycle the key from off to on to off to on to off let go of the unlock button and if the locks cycle from lock to unlock its the new body style and then just press and hold the lock and unlock buttons on the key fob then turn the key back to on its its done. Oh yeh make sure your in the truck with the doors closed. If it is old body style you have to jumper pins 4 and 8 of the aldl connector under the dash until locks cycle and then press and hold both the lock and unlock buttons on the key fob then pull out the jumper. |
