| Junior Member Join Date: Jul 2006
| 01 Sierra Cruise & Blower Motor Question Hello again, Cruise not engaging, I have replaced the brake switch but that did not fix the problem. Fuses are ok, manuel states that 3 wires at the plug going into the servo control should be hot. I'm getting juice at only 2 of them. Should I be looking anywhere else? Also, blower motor operating on only the 2 highest settings. Shouls I replace the switch or the blower motor. Thanks in advance for your help |
| Neither. check the resistor pack . Probally burnt out the lower resistors
| Thanks chevyguy, the resistor pack was the problem. I did a ohm's check on it and found resistance on 1 pin only. $29.00 for a new one at the dealership. works great. |
| Thanks for the help Your answer was right. |
| Glad to help. See ya on the forum
| 2001 GMC 2500 Cruise Control Problem | jim5434 | GMC Truck Forum | 1 | 07-18-2006 01:03 PM |
| should I buy a 2000 Sierra with 4.8L | HuntinTruck | GMC Truck Forum | 6 | 02-13-2006 01:04 PM |
| Four-wheeling in the Sierra: From mild to wild (Sierra Sun) | trucknews | Truck News (headlines) | 0 | 08-10-2005 07:30 AM |
