| Senior Member Join Date: Jul 2005 Location: Yuba City, California
| Brakes? I may sound really stupid here, but I admit my knowledge of auto mechanics is very limited. My front brakes squeak a very high pitched sound. I noticed it when I am just about to come to a complete stop. I only really notice it when my music is low. I heard that it could be because the brakes are dirty and could need to be cleaned. I also heard they may need to be changed, which I found strange because the mechanic I go to told me a year and a half ago that the brakes looked good and woundn't need to be changed for a few years. I am working on improving my knowledge because I am taking Auto Diagnostic and Tune-up. Hopefully this will help me. Any help will be greatly appreciated. P.S. Truck is a GMC C1500 4.3 liter with 102,300 miles on it.
__________________ "Like Gary the No Trash Cougar says, give a larbage, throw out your garbage. Spread the word." |
| Senior Member Join Date: May 2006
| brake pads are cheaper than you probably think, and you probably just need some new ones the sound you hear is probably their little warning system that the pads are getting low. in which case you probably have enough pad left to be safe, but should still change them. if the sound stops when you press on the brakes, then that is deffinitely what it is and a year and a half could be a 'few years' in automotive terms...its all about how (often) you drive your car brake pads should probably be replaced every year or two...whenever they need to be |
| Thanks for your help.
| Senior Member Join Date: Jan 2006 Location: Cali
| Just go out to your truck and look at your brake pads if they are low then you just answered your own questions just get new brake pads... Be careful when turning your rotors because they will only last for so long before you wrap them...
__________________ 2002 F-250 4x4 CC 7.3L DIESEL Mods Edge Evo Edge Juice W/ Attitude 4 Inch Turbo Back Exhaust Straight Pipe DIY Tymar Intake Foil Delete Recon Light Strip |
| Does this seem strange because today my brakes seemed pretty quiet. Only noticed when I was braking in a confined area where the sound of the brakes bounced off the wall. I drove in the same area at the same speed and braked in the same area as yesterday and I didn't even noticed them, even with the music low. Is this normal? Any answers would help and thank you for your reply 02F2504x4.
| O.K. it is one of 2 things, Either its time for brake pads, or you have metalic or semi metalic pads. Its really simple actually. Pull a tire off and look at the pad. There is a small metal piece riveted on the the end of the pad. If it is touching the rotor it is time for new pads, if not them you have metalic pads, No worries. take a look and you will see what i am talking about. Good luck
| Thanks for the info. I will take a look at it tomorrow. Its a little late right now.
| bleeding brakes | jims | Ford Truck Forum | 3 | 01-20-2006 11:24 AM |
| 1998 GMC Suburban Brakes | seadog | GMC Truck Forum | 7 | 01-17-2006 08:32 PM |
| brakes locked up | misslynnerie | Chevy Truck Forum | 3 | 01-07-2006 02:05 PM |
| brakes overheat bigtime but i replaced everything | jazzzmonky | Ford Truck Forum | 8 | 11-13-2005 11:55 AM |
| Investigators find that logging truck had no brakes (New Bern Sun Journal) | trucknews | Truck News (headlines) | 0 | 03-24-2005 11:30 PM |
