| Junior Member Join Date: Aug 2006
| 03 1500 HD in 4-Lo when started Occasionally yy GMC '03 1500 HD is in 4-Lo when I start it. I then swith it back (as soon as I notice). Then in a few days wehn I start it-it does i t again. Any ideas? |
| if it is in 4 low when you drive it you wouldn't get very far before you noticed, the truck would have way more torque at take off. it is probably a bad sensor or switch if you can drive normally and not notice a diiference.
| i think you have a bad switch, or transfer case motor. i assume it is a push button 4wd?
| 1990 chevy 1500 problem e brake light | josh030181 | Chevy Truck Forum | 2 | 08-27-2006 12:29 PM |
| 88 1500 series with AWFUL FUEL MILAGE | chevy_202 | Chevy Truck Forum | 30 | 08-17-2006 06:07 PM |
| Motor in my 1994 Dodge Ram 1500 4x4 | mikejr1226 | Dodge Truck Forum | 12 | 02-22-2006 09:59 AM |
| 90' 1500 Should I buy? | 92Jag | Chevy Truck Forum | 6 | 01-29-2006 10:06 PM |
| 99 Ram 1500 all new parts same old death wobble? | MOPARts | Dodge Truck Forum | 8 | 12-18-2005 11:36 PM |
