Old 10-01-2006, 04:06 AM   #1
Lambru1 is on a distinguished road
Replacing ignition key switch
1982 GMC Jimmy
Pulled off steering wheel, small plastic cover which is next also
I cannot get the column lock plate off, I turned the switch to the on position which releases lock pin, but plate still will not slide off?
Any suggestions? Is there something else here that should be released 1st?
Lambru1 is offline   Reply With Quote
Old 10-01-2006, 06:35 AM   #2
you should be able to push in on it and there will be a retaining ring holding it in place that you need to remove. you can rent a tool from autozone that will help you out greatly.
turn signal switch 79ford4x4 Ford Truck Forum 2 09-30-2006 06:26 AM
Replacing the Clutch John_and_Donna Chevy Truck Forum 2 08-20-2006 02:45 PM
Key wont come out of ignition Brookie Chevy Truck Forum 4 07-20-2006 02:14 PM
stop light switch? billiards GMC Truck Forum 1 06-10-2006 11:21 PM
replacing a 1999 5.4 motor mach Ford Truck Forum 0 05-05-2006 06:38 AM
