Old 01-06-2007, 11:34 AM   #1
shorty27's Avatar
shorty27 is on a distinguished road
1992 GMC problem
The truck has a 350 and still runs great after 200,000 miles. It has of late failed to start on occasion. It will turn over but not fire. Later, it will fire up just fine. I had a problem with the ignition module just over a year ago. Could this be the same problem and if so, what would cause this to re-occur?
shorty27 is offline   Reply With Quote
Old 01-06-2007, 11:47 PM   #2
Chevy808's Avatar
How do you know it's not firing (no spark) on start-up? I'm sure the module is fine after one year. At 200,000 miles, parts are going to start failing -normal wear and tear. If it's not firing it won't start period, let alone later. This means you have spark if it starts at all. You might have another problem all together. You may have the symptom of a failing.....ahem, fuel pump relay.
'85 Oldsmobile 442
Old 01-06-2007, 11:51 PM   #3
I know that the auto parts store can check the part I say theirs nothing better than GM Delco parts look how long the first one lasted you.
Good luck! GMCTRUCKS
Old 01-09-2007, 11:37 AM   #4
03chevy's Avatar
have you put a new ing. pick up stator in it? it's located under the rotor in the dist.
Old 01-27-2007, 11:02 AM   #5
joshnkelly is on a distinguished road
I wouldn't think it would be the ignition. Is the fuel pump turning on?
joshnkelly is offline   Reply With Quote
Old 02-17-2007, 08:50 PM   #6
senior55 is on a distinguished road
I too have a 92 GMC van Vandura 1500 and it is doing exactly the same thing. It first started back in November when I went out, parked the van, came back to start it and it wouldn't. Left it sit for an hour or so and it started. The same thing happened about a month later. Now it is becoming very frequent. When cold, the van starts and after leaving it run for a few minutes, I shut it down and no start. I should mention that when the van doesn't start, there is absolutely no spark and when it cools down there is a spark and it starts. To me it's the ignition module or pick up coil. I sure would appreciate some help here. I should also mention I have close to 197000 Kms and have a 4.3 litre engine.
senior55 is offline   Reply With Quote
Old 02-25-2007, 09:05 PM   #7
Fortyfied is on a distinguished road
A '76 Dodge Tradesman 100 I had was doing that, turned out to be a bad ballast resistor.... the GMs don't have those silly things, do they?
Fortyfied is offline   Reply With Quote
Old 02-26-2007, 05:34 PM   #8
dstrick32 is on a distinguished road
Ignition module (A-C Delco Only) Be sure to put the dielectric silcone underneath it before installing!!
95 Ford F-150XL 5.0 Automatic
92 Chevy Silverado 5.7 Automatic
94 Toyota Ex-Cab 4X4 3.0 Automatic
dstrick32 is offline   Reply With Quote
front brake problem 03 Ford f250 hdkidd Ford Truck Forum 4 10-21-2009 08:59 PM
'99 F250 SD with strange problem ColoQuarterH Ford Truck Forum 4 08-20-2006 10:37 AM
1997 chevy tahoe gage light problem bajaboy Chevy Truck Forum 5 03-23-2006 08:58 AM
1992 Chevy 3500 HD Speedometer problem fisher429 Chevy Truck Forum 0 02-06-2006 07:35 PM
Abs Problem??? MARK326 GMC Truck Forum 1 12-30-2005 01:01 AM
