| brakes pulling hello everybody i,m new here.i was having a problem with the truck pulling bad to the right (bad caliper) so i replaced rotors,calipers,pads, and bearings.my problem is it still pulls to the right but not as bad,it seems to straighten out with steady pressure on the pedal. maybe a bad brake line ? any help would be appreciated. |
| | #2 | |
__________________ '85 Oldsmobile 442 '93 Chevy 2WD C1500 350 Silverado Extended Cab Shortbed '95 Chevy 4WD K2500 454 Silverado Extended Cab Long Bed | |
| Senior Member Join Date: Dec 2006 Location: Bremerton, Washington
| i would say check your brake hoses
__________________ 1979 Crew Cab Chevy 1 Ton Dually 454 |
| change your rubber brake line. i would do both sides just because if you have problems with one then the other being old could go out sometime soon. |
| I agree with 791ton change out your brake hoses my truck WAS doing the same thing. |
| brakes | rdnkmudder | Ford Truck Forum | 3 | 11-03-2006 03:04 PM |
| Brakes? | Beaver3000 | GMC Truck Forum | 6 | 09-03-2006 01:51 AM |
| 94 Suburban brakes pulling right | Fortyfied | GMC Truck Forum | 7 | 06-21-2006 02:35 PM |
| bleeding brakes | jims | Ford Truck Forum | 3 | 01-20-2006 11:24 AM |
| 1998 GMC Suburban Brakes | seadog | GMC Truck Forum | 7 | 01-17-2006 08:32 PM |
