Old 01-12-2007, 04:27 AM   #1
bud-4-u is on a distinguished road
o2 sensor
how much do these cost? the code it throwed was O2 sensor heater ground. Is this one of the sensor or is this a wire burned up on one of them. what is the easiest way to find out which one is out? i have a 2001 gmc 1/2 z71.
bud-4-u is offline   Reply With Quote
Old 01-12-2007, 07:16 AM   #2
Chevy808's Avatar
They'll go anywhere from $20.00-$70.00 each depending on the year. The truck can also have anywhere from 1-4 O2 sensors. If you have more than 1 I would check for the obvious. I really can't tell you how test them. If I'm not mistaken, I think trucks with more than 1 O2 sensors the code will either say "left bank" or "right bank". Not sure though.
'85 Oldsmobile 442
Old 01-12-2007, 07:31 AM   #3
791ton's Avatar
791ton is on a distinguished road
Just replace all of them, since they are all the same age, they most likely need it.
1979 Crew Cab Chevy
1 Ton Dually
454
791ton is offline   Reply With Quote
4 oxygen sensor codes lugnut GMC Truck Forum 1 05-02-2007 12:58 AM
stuck o2 sensor te0417 Nissan Truck Forum 3 01-02-2007 04:20 PM
mass air sensor performance code BUCKMASTER Chevy Truck Forum 5 12-03-2006 04:38 PM
Bad sensor? truckpower Chevy Truck Forum 3 06-28-2006 05:52 PM
1987 Silverado 350 TBI MAP sensor problems 87Silverado Chevy Truck Forum 3 03-27-2006 07:12 AM
