Old 01-14-2007, 04:07 PM   #1
jktuck's Avatar
jktuck is on a distinguished road
How do I drain radiator.
Hey folks, I need to know how to open the pet **** on the radiator on a 99 GMC Jimmy. I think I located it on the passenger side of the radiator, but it looks like I need some special tool to open it or either it looks broken. Want to make sure so that I don't break it trying to open it.
Thanks, Jeff
jktuck is offline   Reply With Quote
Old 01-14-2007, 07:55 PM   #2
should look kinda like a wing nut. Easy to open and close. If it is broken you can buy a new petcock for cheap and replace it. If nothing else take the lower hose loose and let her drain.
Old 01-14-2007, 08:02 PM   #3
Some are a wing nut and some have a square hole in them which a 1/4 in drive extension fits into it and just turn counter clockwise 1/4 turn then it pulls out some
Old 01-15-2007, 09:40 AM   #4
791ton's Avatar
791ton is on a distinguished road
thats howi do it. just be sure to NOT be under the vehicle if you can help it
1979 Crew Cab Chevy
1 Ton Dually
454
791ton is offline   Reply With Quote
Old 01-28-2007, 06:31 PM   #5
jktuck's Avatar
thanks for quick response, however????
Ok guys the 1/4 inch drive was the ticket to opening the drain. I did a quick flush on the system with the heater on full. While I was doing the flush the heater warmed the car great, but now I think the heater core is clogged because it does not heat the car. Should I flush the system again? Should I go with the longer flush process. It may sound cheap but I don't want to flush if it is not going to do anygood. I think the crappy dexcool stuff got too old and glogged it up. The radiator and engine are working fine because the operating temp is perfect.
99 Dodge ram radiator help mudbath Dodge Truck Forum 2 10-31-2006 07:17 PM
newby needs dodge radiator help! mudbath Introductions 0 10-24-2006 06:48 PM
oil in radiator??? s-dimeblaze-her Chevy Truck Forum 9 09-16-2006 08:37 AM
radiator fatboi Chevy Truck Forum 7 09-15-2006 07:20 PM
Have a problem with bugs sticking to your radiator? bubbas91lariat Ford Truck Forum 4 01-03-2006 12:49 PM
