Old 02-23-2007, 07:53 PM   #1
mbarcher is on a distinguished road
1990 GMC K1500 4x4 and brake problems
I have a 1990 GMC K1500 4x4 and have the following problems ...
1- the 4x4 will not engage the front axle .... any suggestions as to why ?
2- my brake light(old abs system) on the dash stays on ... yet parking brake is off and when applies the light gets brighter. Have run a scanner on the truck and removed all the fault codes and light goes out for a while then comes back on ... any way to disconnect the abs and turn the light off ?
mbarcher is offline   Reply With Quote
Old 02-24-2007, 09:22 AM   #2
gmtech has a spectacular aura aboutgmtech has a spectacular aura aboutgmtech has a spectacular aura about
Yeh check connect a test light between the 2 wire connector of the actuator on the front axle if it lights up bad actuator. The abs on your truck should just have a black box mounted next to the brake master cylinder just unplug the wires.
Old 02-24-2007, 03:18 PM   #3
didn't try a test light , but did use a multi tester on the actuator and connected the leads to the 2 wires on unit ... showed there was contenuity between the 2 wires .
As for unplugging the wires at the master cylinder ... will that also disable the fluid level indicator for the resevoir ?
Old 02-24-2007, 07:04 PM   #4
No you need to check to see if you are getting power to the front dif actuator when key is on and in 4x4. The wires you unplug for the abs is a black box alongside of the master cylinder and it has nothing to do with the fluid level indicator
Old 02-26-2007, 06:06 PM   #5
dstrick32 is on a distinguished road
Agree with unplugging the back box, it will not affect fluid level light. You will most likely have to replace the front differential activator. These need to to be used regularly to keep them from freezing up.
95 Ford F-150XL 5.0 Automatic
92 Chevy Silverado 5.7 Automatic
94 Toyota Ex-Cab 4X4 3.0 Automatic
dstrick32 is offline   Reply With Quote
