| timing i just replaced my head gaskets and intake manifold gaskets, i put it all back together and i marked my timing and it started up but it shakes bad, i wont stop shaking, i dont have a timing light im waiting to get it able to drive to the shop to get timed. could my distributer be off 180? also it kinda smokes when i started it, what is going on? |
| when in the same position, i have always loosened the distributor bolt and rotated it a little at a time until i thought that the truck was running right. you might have it off one or two teeth also. |
| i tried turning the distributor, but it run really rough and it gets to the point where it wants to die, it doesnt get any better, would that cancel the theory of skipping a tooth? |
| i think you may have the fireing order wrong. i did that to my dads old cutlass once, neighbor came over and switched a few plug wires and she ran like a champ. |
| i will check to see if i got some plugs messed up. |
| i checked my timing and the order is right what else can it be |
| If it were 180 out it shouldnt run. Sometimes they will but will have a terrible miss/backfiring problem.
| did it get worse either way you turned the distributor?? your timing is messed up somewhere. |
| well i would advance it intell it got to the point where it would almost die and re-tard it the same way and nerver got better. and this time when i started it i broke the belt adjuster |
| what year model is this truck?? how did you break the belt tensioner?? are all your vacuum lines hooked back up to their spots?? |
| 1995 Silverado ignition timing | Mark | Chevy Truck Forum | 10 | 11-15-2009 06:35 AM |
| dodge question on timing | desert ram | Dodge Truck Forum | 0 | 11-12-2006 08:25 AM |
| '93 Escort timing problem | will4831 | Off-Topic | 2 | 11-08-2006 04:33 PM |
| Timing Belt | will4831 | GMC Truck Forum | 11 | 03-27-2006 11:17 PM |
| BorgWarner Supplies Chain-Based Timing Systems to Nissan V6 Truck Engines (The Auto Channel) | trucknews | Truck News (headlines) | 0 | 03-16-2005 10:30 AM |
