| Full Member Join Date: Apr 2007
| Fuel pump, fuel tank, filler neck, filter... I went to replace the fuel pump in my 1998 2500 a couple weeks back and it turned into discovering that my fuel tank and filler neck were almost rusted through in spots. So three weeks later, and a couple hundred bucks out of my pocket, I had everything to put it back together. It went back in great, hopefully I won't have any mysterious problems come up. |
| if that had already rusted out, i believe that i would also check other places for rust. i.e. frame. |
| yeah, it's got some surface rust underneath the truck, but no major areas or rot.....that i've found yet. i just noticed i have a small fuel leak where the fuel line exits the fuel filter. i had to cut the old fuel filter out because i couldn't get the nuts to loosen on either end of the filter. i bought a different style filter, so i could attach a piece of rubber hose before and after the filter. it looks like i need to tighten the clamp on the exit line from the filter. |
| i dont know if i would use rubber hose on the fuel line considering it operates at such a high pressure. if you were using a carbed system or even a TBI, i might could see that. |
| i'll see if i can clamp the hose any tighter....if that doesn't work i'll have to do something else |
| They make high pressure rubber hose. you'll only have a couple inches on each side do you'll be ok. Double up the clamps though.. Were your tank straps bad? one of mine just snapped on me one day. lucky I didn't blow up. walked out to the truck and the tank was hanging 6" off the ground in the rear... oh dear!
| i tightened up the hose clamps on the small pieces of hose and it seemed to do the trick. the tank straps seemed to be fine, i had a good look at them while i was up under the truck. |
| 1987 throttle body fuel pump problem | wojeepster | Chevy Truck Forum | 11 | 10-28-2009 02:53 PM |
| Fuel Pump | SBHoney | Chevy Truck Forum | 1 | 03-18-2007 09:09 AM |
| 1993 Crew Cab Dually- Fuel pump problem? | RodrigoRodrigo | Chevy Truck Forum | 2 | 02-26-2007 05:27 PM |
| The "lift bed" Procedure for R&R tank mounted fuel pump? | Shox | Chevy Truck Forum | 4 | 02-16-2007 12:01 PM |
| Fuel Pump will not turn on? | cab41610 | Chevy Truck Forum | 7 | 07-17-2006 08:33 PM |
