Old 04-05-2007, 07:31 PM   #1
Rawdeal Phil is on a distinguished road
Pitman Arm on 1992 GMC
I'm attempting to replace the pitman arm on my 1992 GMC truck(1500 2 WD),I have the old one off does any one have any tips for putting on the new one,I have it on but getting it all the way up on the spline threads
is a pain I've been using cheater bar to tighten it,thinking the nut would draw it together,but it feels like I'm going to snap something.Input would be appreciated.
Thanks,
Phill
Rawdeal Phil is offline   Reply With Quote
Old 04-06-2007, 06:37 PM   #2
the impact gun is your friend.
i'd rather be hunting
Old 04-07-2007, 07:51 PM   #3
ktate2002 is on a distinguished road
Thanks,
Phill
It doesn't necessarily have to go the entire length up the spline threads. It is a tapered fit. Some arms go on further than others.
ktate2002 is offline   Reply With Quote
Old 10-14-2009, 08:29 PM   #4
illlmikeilll is on a distinguished road
Could Some One verify this?
I am having the same issue, and I dun wanna break any thing
I am using a 3/4 inch breaker bar and the handle from my floor jack and giving it all i got and it aint budging any further.
illlmikeilll is offline   Reply With Quote
Old 10-14-2009, 09:45 PM   #5
BernieB's Avatar
Impact gun is the best way to put those puppies on. But, if you don't have a gun, and you're replacing it with the same stock arm, you should be able to see a line on the shaft where the old one was. It'll be clean below the line and dirty above it; just get the new one up to the line and you should be good to go.
Old 10-15-2009, 05:14 AM   #6
Also if you have a cheap impact it won't do the job but as Bernie wrote look where the old one left a mark and you should be OK. The reason is the wife bought me some Mickey Mouse impact and it wouldn't have the strength to tighten stuff up right like putting in wheels studs so I bought me a Sears impact that did it.
1992 Ford F-350 Xlt Dually*crewcab*custom Graphics mrhaney Truck Classifieds 0 11-13-2006 10:13 AM
1982 1/2 ton 2WD - pitman arm not fitting on streering pump all the way m_seuf GMC Truck Forum 2 10-05-2006 12:01 AM
1992 Driveshaft Noise??? pattard Chevy Truck Forum 2 02-12-2006 08:56 PM
1992 Chevy 3500 HD Speedometer problem fisher429 Chevy Truck Forum 0 02-06-2006 07:35 PM
Info On 350 Rebuild For 1992 Chevy CUSTOMRODS Chevy Truck Forum 1 12-01-2004 03:09 PM
