Old 06-15-2007, 12:58 PM   #1
derral is on a distinguished road
abs activation at low speed after hub replacement
I have a 2000 gmc sierra. I just replaced both front hub bearings. Now when I am braking the abs activates when I am almost stopped causing the truck to roll into intersections and such. Does anyone have any idea what the problem could be. I have the same results with new and old wheel speed censors.
derral is offline   Reply With Quote
Old 06-15-2007, 02:44 PM   #2
Moderator
is the truck 2 wheel drive? you mentioned swapping speed sensors so i'm gonna guess 2 wheel. did you adjust the air gap properly. if you installed the sensor to close to the tone ring then it will assume the front tires are spinning faster than the rears and will activate the ABS system when you try to stop. you will need some non-metallic feeler gages and the owners manual to set the correct gap.
member map add yourself
Old 06-15-2007, 03:19 PM   #3
our wheel
it is four wheel drive. and my manual says nothing of adjusting the air gap. and i see no way to get a feeler gauge insid of the hub bearing assembly.
Old 06-15-2007, 03:20 PM   #4
also the new hub assemblies came with the wheel speed sensors already installed.
Old 06-15-2007, 05:50 PM   #5
Moderator
well, i guess that made my post useless than. 4 wheel drive speed sensors are non-adjustable thats why when you mentioned swapping sensors i figured 2 wheel drive, although i'm not sure if that is true on the newer trucks.
do you have any brake lights lit on your dash? i would pull the ABS maxi fuse under the hood and take the truck for a drive and see if it still acts up, if so the ABS is most likely fine and it is the base brake system with the problem. then we can go from there.
Old 06-15-2007, 05:53 PM   #6
the brakes work perfect with the fuse pulled
and no idiots are lit
Old 06-15-2007, 05:54 PM   #7
also took it to a good mech. he hooked it up on his computer said everything is normal
Old 06-15-2007, 05:55 PM   #8
Moderator
are you sure the light is not blowen? remove a connection from one of the sensors and start the truck, the computer should pick up on the lost connection right away. i'll check some of my books some more.
Old 06-15-2007, 05:56 PM   #9
Moderator
now you got me puzzled, i get back to you in a minute.
Old 06-15-2007, 05:59 PM   #10
lights come on with speed sensors un hooked and the brakes function normal while they are unplugged
3 speed automatic to 5 speed manual help torino Ford Truck Forum 12 02-25-2006 06:17 PM
Speed Channel Truck Stop: Bill Lester (Speed TV) trucknews Truck News (headlines) 0 07-20-2005 01:30 PM
SPEED Channel Continues to be the Exclusive Home of the NASCAR Craftsman Truck Series (Speed TV) trucknews Truck News (headlines) 0 01-25-2005 09:30 PM
ASA Speed Truck Challenge Renewed for 2005 (Speed TV) trucknews Truck News (headlines) 0 12-15-2004 03:30 PM
Relive the 2004 Craftsman Truck and Busch Series on SPEED (Speed TV) trucknews Truck News (headlines) 0 12-15-2004 03:30 PM
