Old 07-25-2007, 06:47 PM   #1 (permalink)
NH_Bert is on a distinguished road
Is an Oil Pan Replacement Beyond My Means?
98 GMC K3500 1 ton dump 4x4 which is rusting like ****! Last year replaced the fuel tank and a brake line. Now the oil pan is leaking! Is this something an average ability guy can do? Also, was thinking of applying Rust-Mort by SEM paints to the frame to stop the rust, then coating it with under carriage spray. Whtdya think?
Thanks
Bert - NH
NH_Bert is offline   Reply With Quote
Old 07-26-2007, 02:31 PM   #2 (permalink)
Moderator
bradrhale is a glorious beacon of lightbradrhale is a glorious beacon of lightbradrhale is a glorious beacon of lightbradrhale is a glorious beacon of lightbradrhale is a glorious beacon of light
where is it leaking from?? the pan or the gasket?? neither one are a major problem except for the crossmember thats in the way. make sure what is leaking before you go replacing parts. dont know about rust mort. sorry
Old 07-26-2007, 03:51 PM   #3 (permalink)
greasemonkey's Avatar
greasemonkey is just really nicegreasemonkey is just really nicegreasemonkey is just really nicegreasemonkey is just really nice
Try to trace the leak to it's origin first. As for the rust, if you can Id have the frame sandblasted then treated. If you just cover up the rust, it will only come back many times worse. If you cant get it sandblasted, treat it with Naval Jelly. This is the same stuff they use on ships to stop rust.
Tractors are like watermelon, you keep the red and throw away the green."
greasemonkey is offline   Reply With Quote
Old 07-26-2007, 04:38 PM   #4 (permalink)
72'CaminoKid's Avatar
72'CaminoKid is just really nice72'CaminoKid is just really nice72'CaminoKid is just really nice72'CaminoKid is just really nice72'CaminoKid is just really nice
naval jelly works good. i've always wondered why its claled that though. guess the ship thing is where it comes from
99 suburban xlt
96 silverado
91 wrangler (my baby )
72'CaminoKid is online now   Reply With Quote
Old 07-27-2007, 10:04 AM   #5 (permalink)
Moderator
camino, it comes from your navel. ****, even i knew that.
Old 07-27-2007, 10:31 AM   #6 (permalink)
Moderator
mudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to behold
that just spoiled my appetite for lunch. well...... maybe one sandwich.
Old 07-27-2007, 05:35 PM   #7 (permalink)
i tried toe jam once. didnt work nearly as good
99 suburban xlt
96 silverado
Old 08-02-2007, 10:22 AM   #8 (permalink)
NCroadracer's Avatar
NCroadracer will become famous soon enoughNCroadracer will become famous soon enough
Not a hard job, but you'll have to get the front differential assembly out of the way first... and on the ground without a lift, that will be nearly impossible, unless you can get it a good 24" off the ground.
NCroadracer is offline   Reply With Quote
abs activation at low speed after hub replacement derral GMC Truck Forum 15 06-20-2007 04:16 PM
Keyless entry control unit replacement bodean Chevy Truck Forum 3 02-19-2007 02:44 PM
need website for replacement seat mulawdaog Chevy Truck Forum 9 02-14-2007 05:10 AM
Dodge Front End Replacement thsboss99 Truck Classifieds 0 11-26-2006 06:23 PM
Ball joint replacement vettman Chevy Truck Forum 3 08-20-2005 01:29 PM
